Cooling system
Old Jul 19, 2004 | 03:26 PM
AZMike's Avatar
AZMike
Default Cooling system
I own a 1994 C4 Coupe with 68,000 miles. I live in Az and am about to add 40 below to the system as I am having cooling issues in town with all the short stops and need to know what the coolent fluid cpacity in gallons.
Can ayone help out here.
Thanks in advance,
Old Jul 19, 2004 | 03:33 PM
elkabong's Avatar
elkabong
AZMike - Before you add the stuff make sure area between the AC condenser and radiator are free of debris. This is a common problem and you will be amazed the amount for crap that accumulates there. I understand what you are dealing with in AZ - I live in Chandler.
Old Jul 19, 2004 | 03:53 PM
Red Dwarf's Avatar
Red Dwarf
Vin P capacity, cooling is 17.8 Qts. For gallons divide by 4.
Old Jul 19, 2004 | 06:04 PM
c4cruiser's Avatar
c4cruiser
Adding stuff to the coolant is not the best fix unless you have checked out the cooling system for any potential problems. Junk in the front of the radiator is the biggest problem Corvettes have with effective cooling. You can direct a stream of water from the fan side through the radiator fins to loosen any debris from the front of the radiator. Make sure the A/C condensor coil is clear too.
The system is designed to run hot for helping with emissions so seeing temps anywhere from 197 to the low 230's is normal. The secondary fan is supposed to come on at 228 so make sure it runs. Turning on the A/C forces the secondary fan on.
Check the radiator hoses for softness. If the lower hose is soft it could be collapsing and cutting of the flow of coolant. Do a complete coolant system flush every other year using a good ethlylene glycol (green)antifreeze and distilled water in a 50-50 mix.
Old Jul 19, 2004 | 06:09 PM
BowTieBlood's Avatar
BowTieBlood
Meziere pump
Old Jul 20, 2004 | 01:04 AM
JScott 88 C4's Avatar
JScott 88 C4
Good time to change the thermostat / gasket. Check the cooling hoses, especially to the throttle body & lower radiator hose. Add a Prestone flush kit and flush the system. Pull the knock sensor to drain the block. Add the new coolant.
Old Jul 20, 2004 | 01:08 AM
vader86's Avatar
vader86
In AZ I would not hesitate to run a 160 thermostat.
You should check the space between Condensor and Radiator, and the only way to do so is removing the shroud, dont be lazy and try to get it from underneath.
Flush and refill the system, see if its any better.
Old Jul 20, 2004 | 08:06 AM
runner140*'s Avatar
runner140*
Default running warm
I live in south Florida and it gets hot down here also. An easy tip is
to check the 3" space between the radiator and the A/C condensor.
The easy way to check this is with a flash light and look at a 2 1/2"
space on the passengers side. You can get a clear view of what is in
there and isnt. A long tube(3' PCV pipe) attached to a vacuum cleaner
will clean the entire radiator. I've made some adjustments on the 3'
extention pcv pipe like cut a 45 degree angle at the end. Try it.
Old Jul 28, 2004 | 06:29 PM
AZMike's Avatar
AZMike
First thanks for all of your replies, its not every time that I get people to reply.
Now I have a new belts water pump, the radiator front and in front of the condensor is clean. I have seem some real garbage in there from time to time and I always try to avoid road trash when I can. I just changed the thermostat to a 160 and have been running on it for two days now.
It helps from the standpoint that it takes it longer to heat up and when I run with out the ac I can now stay at 227 degrees if I'm not idling for extended periods of time in traffic.
I do however still have the same issue when I run the AC and in Arizona you need the AC this time of year.
Has anyone used the cooling additive 40 below? It is sold by ecklers and mid america. Are there any issues to look out for if I were to use it.
Old Jul 28, 2004 | 06:39 PM
comp's Avatar
comp
clean between use distilled water and your anti freeze/boil
coolant mix 50/50 good for most of the place (most)
Old Jul 28, 2004 | 07:18 PM
nobodyunknown's Avatar
nobodyunknown
40 below is for sale at autozone,$20.
Is your front air dam connected properly?
Try a fan switch that comes on at 200 degrees.
Old Jul 29, 2004 | 01:49 AM
AZMike's Avatar
AZMike
I have the 40 below and distilled water. As for the air dam how do you tell? It seems like there is nothing stopping or restricting air flow.
Old Jul 29, 2004 | 03:35 AM
skeet's Avatar
skeet
I used 40 Below years ago in my 85. It was in the system for about 7 months when I started to hear a hissing sounds from the radiator cap. When I opened the cap there was a thick sludge that was preventing the cap from sealing. It took many flushes to get the system clean again. The system was spotless before the 40 Below. Besides that I never saw any type of temperature reduction at all.
Old Jul 29, 2004 | 01:35 PM
BowTieBlood
Try Red Line Water Wetter
Old Jul 29, 2004 | 01:48 PM
black_89_vette's Avatar
black_89_vette
I have used straight distilled water and a can of 40 Below. My coolant temperatures dropped by a fair bit, but this was also the same time that a fan motor was going out of me.
I have yet to try the Redline Water Wetter, although I have a bottle of it. Right now, I have no cooling issues, so I guess I'm too lazy putting the Water Wetter in.
Old Nov 21, 2004 | 02:01 PM
AZMike's Avatar
AZMike
Default Thanks -
Hello all,
Sorry it took me so long to reply. Here is the fix that worked for me. I needed a new radiator. The one I had was not flushed frequently by the previously owner. I bought an after market replacment for $160 and now never see a temperature in the summer months above 228F when sitting in traffic.
Thanks for all the inputs.
To Cooling system
