Any tips on 02?
Old Jul 21, 2004 | 11:02 AM
rick lambert's Avatar
rick lambert
Default Any tips on 02?
After spending waaaay to much time replacing my antenae mast-Thought I'd ask for any tips on replacing the 02 sensor on my 87.Thanks in advance Guys. You're the best.
Old Jul 21, 2004 | 12:15 PM
myblue91's Avatar
myblue91
Replaced mine with a bosch sensor last month. Found a socket for the R&R of the sensor at Sear for $6.99. Just get the exhaust hot,protect your hands and arms,and take it off.(do remove the wire first).Mines a 91 and your's should be similiar. Good Luck
Old Jul 21, 2004 | 12:38 PM
rick lambert
Thanks Myblue91 just the info I was looking for.
Old Jul 21, 2004 | 12:39 PM
Swirk's Avatar
Swirk
I agree get it hot first and then try to get the sensor out. I have had to use a torch to get them out before. When you put the new one in, make sure it has a coating of anti-seize on the threads. You will appreciate it if you ever have to remove the sensor.
To Any tips on 02?
