When to replace shocks?
Old Jul 22, 2004 | 11:43 AM
Scooter 94's Avatar
Scooter 94
Default When to replace shocks?
I've got 53,000 miles on my '94 LT1 w/standard suspension. Is it time to change shocks? Feels jittery over bumps in a turn but I can't remember if it's always been that way.
Old Jul 22, 2004 | 07:52 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Shock mileage may vary
Those that hardly drive their cars may not realize the shocks are bad for at least 100,000 miles
Fairly serious drivers start to ask questions at around 50,000 miles
Others, who may be a little nuts like me, replace at around 30,000 miles
Seriously, most people go way beyond the usefull life of the shock. If it is feeling jittery, then it is probaly the shocks.
I get about 30,000 miles out of mine before I feel the difference in the handling
It depends on how you drive it...push it hard around the twisties, lower shock life
Old Jul 22, 2004 | 08:50 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
On a related note; are the Bilstiens really worth the money? I`ve got the z52 suspension on my `87, & the car only has 34,000 miles on it, but I swear that if I rolled over a quarter, I could tell if it was heads or tails.
Ken
Old Jul 22, 2004 | 09:18 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I have 123,000 miles on the original shocks. Still going good, but I will be changing them soon just because.
Old Jul 22, 2004 | 09:21 PM
Rocky Rothrock's Avatar
Rocky Rothrock
I replaced my originals on my 87 at 90000-they were completly shot!
Old Jul 22, 2004 | 09:36 PM
Strick's Avatar
Strick
I was wondering this myself. I added a cross-bar and a camber-brace and no more (as you say) jittery feeling over the bumps. (I call it a wobbling after a bump) Now my 49K OEM shocks feel much better. I'd still like to beef them up a little.
Old Jul 22, 2004 | 10:02 PM
Scooter 94's Avatar
Scooter 94
The chassis could definitely be stiffer, makes it hard to tell if it's the shocks. Feels to me like it needs a softer shock to keep the back tires stuck to the road. Instead they seem to come unglued and the back end wants to skip out in the turns.
Old Jul 22, 2004 | 10:12 PM
vader86's Avatar
vader86
It is difficult to tell with the Bilsteins. They do tend to ride worse after time, my new ones are Z51 too and they actually ride better than the originals did.
Usually though, they are gone at around 75K for most drivers.
If you race alot, possibly 50K.
But if theyve been sitting alot, unless you see alot of leakage or your ride is really choppy (or it tends to 'float' on the hwy), I wouldnt worry about them yet.
Bushing wear is probably more prevalent/noticable.
Old Jul 22, 2004 | 10:18 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
FWIW, I replaced my 70K OEM Bilsteins with a 15K set I bought from CF member JB666 (he of the free headliner material fame) and immediately noticed a difference, the most obvious effect being that I very rarely bottom out on speed bumps any more. I also notice the front end doesn't seem to "float" as much at higher speeds (70-80 mph). Even without prompting, my wife said the car seemed to ride smoother...
Old Jul 23, 2004 | 08:10 AM
runner140*'s Avatar
runner140*
Default Shocks
Judging form the posts, most of us are using old shocks that should be
replaced. Its a thing on our list that seems to be put off for to long. I
have 78000 miles and will change mine in the near future.
Old Jul 23, 2004 | 09:40 AM
joseph p's Avatar
joseph p
I bought my car ('89 Coupe)used with 106K on it. It has Bilsteins that don't show leaks but the ride is hard as hell. I bought new tires and a new rear spring, and I've always owned Vettes, but this is my first one with low profile 17" wheels. I assume alot of the harshness is from the low profile but I would replace the shocks if I knew they would help. Does anyone have a softer, less jarring ride suggestion?
Old Jul 23, 2004 | 09:45 AM
vader86's Avatar
vader86
The bigger wheels actually helped my ride quality. You may want to replace the bushings and also change shocks to something softer if ride is still bothering you.
Old Jul 23, 2004 | 03:00 PM
dennisvet's Avatar
dennisvet
Navigator
Default about time, I guess
I have 156,000 miles on my original shocks now. The ride still seems pretty smooth but I think I will change mine soon, just because it feels like it must be time..also they have started to develop a small leak.
Old Jul 23, 2004 | 04:04 PM
joseph p's Avatar
joseph p
"You may want to replace the bushings"....
Which bushings are you speaking of, Vader. Any specific recomendations for softer shocks?
Old Jul 23, 2004 | 04:29 PM
JAKE's Avatar
JAKE
I'm sure he's referring to upper and lower control arm bushings.
Gabriel VHT (I believe they're called VHT) gas shocks are soft riders. I've seen them at Pep Boys.
Jake
Old Jul 23, 2004 | 07:28 PM
mitchcole's Avatar
mitchcole
I never liked the original shocks on the base suspension. Just too soft - off the showroom floor.
I did the KYB thing. You'll get comments positive and negative. Negative is mostly from the autocross and racing guys who will spend the $500 for the Konis. Overall they work really well - and for the price - can't be beat.
I'd stay away from the monroe, the only cheap shock that works is KYB.
Old Jul 24, 2004 | 07:12 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I know Bilsteins are not your ordinary shock, but come ON.....
I find it strange that so many Corvette owners change oil every 2-3 thousand miles, but insist on getting 80, or 90, or 100K miles out of the original shocks.
If you want to get 150K miles out of a shock, it had better be a GOOD, adjustable unit.
Larry
code5coupe
Old Jul 26, 2004 | 11:36 AM
joseph p's Avatar
joseph p
"I know Bilsteins are not your ordinary shock, but come ON.....
If you want to get 150K miles out of a shock, it had better be a GOOD, adjustable unit."
I agree, is there a place that rebuilds Bilsteins? Or is it better to just replace?
Old Jul 26, 2004 | 11:47 AM
tobijohn's Avatar
tobijohn
Bench Racer
...I agree, is there a place that rebuilds Bilsteins? Or is it better to just replace?
If you just want them rebuilt to the original OEM factory specs, once you include your shipping costs it's cheaper to buy them new as Bilstein charges about $65 plus any parts plus shipping for each. However, if you want them for a specific purpose such as autocross, etc, they will also revalve them for you so in that case you might want to have them do it...
To When to replace shocks?
