What are cut back style sparkplugs
Old Jul 22, 2004 | 12:59 PM
rws.1's Avatar
rws.1
Default What are cut back style sparkplugs
I've read in a number of places that cut back style sparkplugs will improve performance.
Exactly what are they?
Does one make them by cutting back the electrode or does one buy them?
If former how do I cut them, If latter, can Ihave a recommendation on a brand and source for my 88
thanks
Old Jul 22, 2004 | 01:09 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
They are plugs that have the ground (side) electrode trimmed back so that the end lines up with the SIDE of the center electrode. The theory is that it "unshrouds" the spark.
If you draw a picture of both styles and place a spark in the appropriate place in each drawing, you'll see that it does nothing.
Save your efforts...if this was a valid power-maker, EVERY plug maker would make their plugs this way.
If you insist on spending time and money on gimmicks, buy a Tornado...at least you get a decal.
Larry
code5coupe
Old Jul 22, 2004 | 01:11 PM
RED-85-Z51's Avatar
RED-85-Z51
I just changed my plugs this morning, I cut them back, per 65Z01's instructions.
I used my cut-off rotary tool to trim a little bit off the end of the electrode on the stock style plugs. Dont use rapid fires!
They are stock AC-Delcos, and it does seem to work, the car starts faster now.
Old Jul 22, 2004 | 01:14 PM
rocco16's Avatar
rocco16
Originally Posted by RED-85-Z51
I just changed my plugs ... the car starts faster now.
I should...it has new plugs.
DOH!!!!
Larry
code5coupe
Old Jul 22, 2004 | 01:37 PM
Steel Blue 91's Avatar
Steel Blue 91
Here's a quote from 65Z01's page about the effects of the cut back plugs:
"Test Results
After running cut-back Split Fire spark plugs for some time at the strip, I installed some unmodified Rapid Fire spark plugs at the same gap setting and subsequent trap speed was down by 1mph. The following weekend, with the old cut-back spark plugs back in trap speeds were up by 1mph, to their former level. This 1mph increase in trap speed is equivalent to a gain of about 10 HP".
You decide if it's worth it.
Old Jul 22, 2004 | 05:47 PM
Ramanstud's Avatar
Ramanstud
Racers have been cutting plugs for decades- the reason large manufacturers don't do it is because it decreases the life of the plug and the gap can change more quickly with wear. If you look at the splitfire (bosch 4+ or whatever), you'll notice that they DO trim back the electrode, but insert 2 or three more to extend the life of the plug. I think it's worth it, if only for peace of mind.
Old Jul 23, 2004 | 08:15 AM
runner140*'s Avatar
runner140*
Default Cut backs
Great comment from Rocco16. His comment hit the nail on the head.
Old Jul 23, 2004 | 06:47 PM
Billz89's Avatar
Billz89
This makes perfect sense to me. Not that the others don't, yes better spark, yes more wear. Less wear with 4 electrodes.
To What are cut back style sparkplugs
