OBDI or OBDII
I've seen the replies saying some '94s had OBD II and I say
Although I have not disected the '94 PCM code, I'm told that it contains some elements of the OBD II strategy for field testing purposes. I would imagine this is primarily tied to the added o2 sensor.
Lastly, OBD II powertrain codes are Pxxxx where "xxxx" is a number such as 0300 or P0300 when displayed using a scan tool and you can't use the "paperclip trick" to display them since they're too long to display on the speedo. The OBD I codes are H (history)xxx or C(current)xxx where xxx is a number such as H031.
http://www.arb.ca.gov/msprog/obdprog/obdprog.htm
not to nitpick, but OBD-II is actually a California (CARB) requirement, while the Feds just call it plain ol' OBD. their requirements differ only slightly.
Jim is right on with his explanation of the 94 Corvette being OBD-I. there are probably shades of OBD-II features in pre-96 vehicles due to the fact it didn't make sense for GM to wait for the 11th hour to develop and introduce the newly required diagnostics. some of these diagnostic algorithms are not trivial to develop.
Sort of like mixing metric and english fasteners on their cars....
The "bean counters" like to keep us guessing...
