AIR pump removal?
Old Jul 23, 2004 | 06:16 PM
philly1919d's Avatar
philly1919d
Default AIR pump removal?
How many of you guys have removed their Air pumps from your L98s. Zip offers the underdrive pulley set for it for $160. Is this a worth while investment? Any negative effects from it?
Old Jul 23, 2004 | 06:59 PM
Upstate's Avatar
Upstate
From: [Quote=WOEII] Is dried brown doodie powders man! [/Quote]
The only negative impact is going to be on your emmissions. If you need to get smogged you will be SOL. You will be rewarded with a much cleaner and less clutered engine compartment, and maybe a pony or two. I eliminated my pump along with other mods done at the same time so I can't really tell if it made a difference.
Old Jul 23, 2004 | 07:36 PM
SunCr's Avatar
SunCr
Raw air into the headers at startup has an afterburner effect getting it to closed loop faster so if you eliminate it, consider a heated O2.
Old Jul 23, 2004 | 07:41 PM
korvette4u's Avatar
korvette4u
built my own
Old Jul 23, 2004 | 07:54 PM
vader86's Avatar
vader86
You can pass the sniffer without it, but you may not pass visual in California.
Its more of a cosmetic mod than anything.
To AIR pump removal?
