Cam Timing ???
Old Jul 23, 2004 | 11:39 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
Default Cam Timing ???
Can someone please explain Cam Timing to me. I understand the basics, My question is about the -4 +4 or 0 advance timing.
Old Jul 24, 2004 | 02:20 AM
Rick86's Avatar
Rick86
I'm no expert but changing the cam +/- 4 degrees will shift your powerband to give you more bottom end or more top end power depending on which way you go. Most cams already have some advance built into them and you should probably install them at 0 degrees. Check with the cam manufacture to be sure.
Old Jul 24, 2004 | 04:28 AM
TIMSPEED's Avatar
TIMSPEED
Most cams come with 4º advance ground in.
Old Jul 24, 2004 | 08:50 AM
SS409 425HP's Avatar
SS409 425HP
Go to www.chevytalk.com/tech/101/cam_theory.html You said you have an understanding of the "basics", so some of it will be redundant. There is a section that explains the advanced vs retard timing. Edit: I don't know why the link I just posted doesn't work. I'll try to see what went wrong.
Old Jul 24, 2004 | 09:21 AM
Rich & Lisa_84
I made it to the article. Thank You for posting it.
http://www.chevytalk.com/tech/101/Cam_Theory.html
Old Jul 24, 2004 | 09:26 AM
SS409 425HP
Here's another good "camshaft" link. http://www.newcovenant.com/speedcraf...camshaft/3.htm
To Cam Timing ???
