HELP!!!!! Parking Brake will not release!!!!
Old Jul 24, 2004 | 05:31 PM
Rudy525's Avatar
Rudy525
Default HELP!!!!! Parking Brake will not release!!!!
Put Parking break on to work on Shfter **** and When I went to take it off nothing happens. I can't drive the car now.....HELP!!!!!
What do I do?
Old Jul 24, 2004 | 05:45 PM
Perfusion's Avatar
Perfusion
So what you're saying is, you've disengauged the e-brake (i.e., it felt like it released and went to the floor), but the car physically won't move? Or can you just not get the e-brake to disengauge? Is the "Park" light still lit on the dash? More info please!
Old Jul 24, 2004 | 06:07 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Hold in the button while lifting the handle again. You should hear it disengage.
Old Jul 24, 2004 | 06:20 PM
Rudy525's Avatar
Rudy525
I released the E brake handle and nothing happens. Light is lit in dash, drove car around the block and brakes were smoking. I can not get it to disengauge. Linkage under car seems to be fine. Handle does not acuate the srping by the mufflers. Do you think its a broken cable or the the part connects it to the lever came off?
Old Jul 24, 2004 | 07:06 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
you have to pull up the handle & release it again ( the procedure is in the owners manual )
Old Jul 24, 2004 | 08:40 PM
jabez's Avatar
jabez
unscrew and take the cover off the e-brake. poke a screw driver in and dis-engage the brake.
Mine was broken when I got the car. I used this method until I had it fixed.
Someone may have "overpulled" the brake handle and the lever may have over shot the teeth.
Old Jul 24, 2004 | 10:04 PM
Rudy525's Avatar
Rudy525
Thanks to all. I'll try it tomorrow.
Old Jul 25, 2004 | 12:33 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If pulling it further witth the button in doesn't work, I'd try taking the seat out and removing the cover. There's a slider in there with an e-clip on it that falls off, and the piece comes out.
To HELP!!!!! Parking Brake will not release!!!!
