Cleaning stock wheels
Old Jul 24, 2004 | 07:54 PM
Stv50's Avatar
Stv50
Default Cleaning stock wheels
I have a 1996 with the stock saw blade rims. I have noticed that after the last wash and shine i see a milky discoloration on two of the wheels. It's not a lot, just a few places. Is there anything out there I can use safely to clean or polish them without messing them up? Thanks in advance.
Old Jul 24, 2004 | 08:14 PM
J Z06's Avatar
J Z06
You can try a wheel cleaner made for clear coated wheels.
The symptom you describe SOUNDS like the clear is discoloring. It isn't out of the ordinary for that to happen. A lot of heat from the brakes/driving over time will do that. If you can't get the wheels to your satisfaction...a re-finish might be in order.
Old Jul 24, 2004 | 10:01 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Thats it
Old Jul 24, 2004 | 11:55 PM
avtt94's Avatar
avtt94
Some cleaners can cause this problem.I use A2Z from Eagle One and it is great stuff.It will clean your wheels and tires with one product.
Old Jul 25, 2004 | 10:07 AM
89vert's Avatar
89vert
I have an '89 with salad shooters on it and the clear coat needs to be redone. I have been using Turtle Wax 2001 protectant on them until I get them refinished. You would be surprised how much it helps.
Old Aug 1, 2004 | 02:45 PM
rtpilot's Avatar
rtpilot
Default Me Too
Had it happen to me with Wheels on Yukon after going threw car wash. Noticed whitish stains on wheels (clear coat). Car wash took no responsibility (no surprise) use armorAll to mask problem. What a mess! Just got a new C5 yesterday. What do you use to clean Highly Polished Wheels
Old Aug 1, 2004 | 03:04 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I too have used their products with good results.
Old Aug 1, 2004 | 03:52 PM
PSO3120's Avatar
PSO3120
Soap and water and a good wash mit.
Old Aug 1, 2004 | 07:34 PM
redfast's Avatar
redfast
Wheel cleaner spray one....hose off
To Cleaning stock wheels
