Spring Squeek Removal
Old Jul 25, 2004 | 10:37 AM
884fun's Avatar
884fun
Default Spring Squeek Removal
How does one go about getting the composit springs to stop squeeking over every bump? I've tried spraying with food grade silicone which works but for only a short while.
Old Jul 25, 2004 | 03:32 PM
bogus's Avatar
bogus
this is caused by the spring meeting the rubber bushings.
hit the bushings with grease. should help. but be carefull. the wrong grease will harm the springs glue that holds it together.
I would try the grease used in bushing kits.
Old Jul 25, 2004 | 06:02 PM
JasonL's Avatar
JasonL
Are you sure it's not the sway bar bushings?
Old Jul 26, 2004 | 01:32 AM
Frizlefrak's Avatar
Frizlefrak
Most clunking noises in the front end can be attributed to worn sway bar bushings. When they wear out, they go metal to metal, and can squeak or grind when you go over a bump.
It's a cheap and easy fix....check it out.
Old Jul 31, 2004 | 04:21 PM
884fun's Avatar
884fun
Yes I'm sure.
I replaced them 2 years ago. I tried Energy Suspension bushing from Mid America but they were too small and the bar clunked so I replaced those with new OEM.
This is the spring that's making the noise/squeek. Not a clunk or clank or thud but a creak-creak, creak-creak, creak-creak when going over speed bumps, fast dips, road kill, in-laws, etc.
Old Jul 31, 2004 | 07:35 PM
C10 JDR's Avatar
C10 JDR
" in-laws etc"
To Spring Squeek Removal
