Replace or Clean/Service Radiator?
Old Jul 25, 2004 | 01:24 PM
Dolfan's Avatar
Dolfan
Default Replace or Clean/Service Radiator?
I've read quite a bit about people cleaning up the area between the condensor and radiator and I just started the job. Haven't removed the radiator yet but I'm curious. I know I should see maybe a 10-20 degree improvement in cooling which is great. But as my radiator is original, should I coonsider a replacement? Not with a super efficient alluminum as my motor is stock, but just a after maket new replacement. After all the radiator is 15 yrs old.
During autox event in the summer I'm seeing temps of about 225-230 as I begin my runs and that is beginning to make me nervous. Also noticed on the highway during summer it is getting up to about 200-205 with AC on.
I'm guessing I could pick up a new radiator for less than $175? Just thought since I've got it out maybe replace?
Ideas?
Old Jul 25, 2004 | 01:40 PM
CFI-EFI's Avatar
CFI-EFI
Nothing you've written suggests it ought to be replaced. Mine is 20 years old and still going strong. While it's out, you may want to run it by a rad shop to have them flow test it and offer up an opinion, but it sounds good, from here.
RACE ON!!!
Old Jul 25, 2004 | 04:12 PM
Dolfan's Avatar
Dolfan
I was thinking to take into a shop for a quick test, I agree that it doesn't appear to be faulty. Just not sure how much money I should inest in a 15 yeat old radiator. I found one online at autoradiatorsdirect.com for about $119. If it is equal to stock then why would I spend $40-$60 testing mine?
Can't shop actually clean the inside pretty well? If that is the case it might be worth it.
Just a thought, don't feel like pulling it out again in 1-2 years if it fails just to save $70.
Old Jul 25, 2004 | 06:05 PM
comp's Avatar
comp
i'd have it checked and re-use
Old Jul 25, 2004 | 08:11 PM
snaketr's Avatar
snaketr
I have a DeWitts, I can be in traffic with the A/C on and my car runs 177-190 with out the A/C it never goes above 185.
Old Jul 25, 2004 | 08:22 PM
CFI-EFI's Avatar
CFI-EFI
If you pull the rad, I can't imagine the testing and/or cleaning costing that much. If you DO decide to replace it, make sure that $119.00 wonder has an aluminum core and is made in the US. There are cheap copper/brass replacements out there that are nowhere near OE quality. Foreign replacements often have inferior bonding between the tubes and fins, inhibiting effecient heat transfer. You won't beat a Modine, as a replacement.
RACE ON!!!
Old Jul 25, 2004 | 09:06 PM
Stingraynut's Avatar
Stingraynut
I had the radiator shop pull the plastic ends off and soak it overnight to remove build up - it made an amazing difference
BUT
6 months later my radiator sprung a leak cause from long term expansion /contracting on damaged fins and I had to but a new one anyway - I was running so cool in our tropical winter that I also had to swap the 160 degree thermostat for a 180 - everything is really good now - but my new radiator and thermostat cost Aus$650 ( US$460) I hate it when I hear you can get stuff so cheap - wish I had a 'cost filter' on my browser.
S'nut
vader86's Avatar
vader86
I dont see any reason to replace it, not unless you want to upgrade to the more expensive ones like BeCool, Griffin, etc.
Just flush it, check for leaks, and reuse it.
Old Jul 26, 2004 | 08:37 AM
runner140*'s Avatar
runner140*
Default Clean or replace
Radiators will last up to 20 years but a least 10 years. First move
should be to clean the radiator( the space between the radiator and
the a/c condensor. On the passenger side there is a space to view
the condiction and if there is a problem. Flush and use a good coolant
50/50 mixture. See if this works, if not replace the radiator.
Old Jul 26, 2004 | 09:21 AM
Strick's Avatar
Strick
Here is my thoughts on this. I, too, figure that if I take something out, you might as well replace it (within reason of course). However, if the radiator was well maintained, it should be just fine. The only part of the radiator that I would be concerned about is the plastic end caps, which you can order. I've seen them split. So, clean it up, inspect it, and have the shop test it. If needed, I would use an OEM radiator to replace it. They work good and last a long time. Now if you had a 383 or 396, maybe go with an aftermarket one with additional capability.
To Replace or Clean/Service Radiator?
