ASR question
Old Jul 25, 2004 | 01:48 PM
jabez's Avatar
jabez
Default ASR question
Seems like my ASR is going out. I get the service ASR light.
Can i fix it? What is involved? If i take it to a dealer or mechanic what type of pricing will I expect?
Fixing it isn't a major priority right now since I normally turn it off anyway but the "service ASR light" really irritates me.
Old Jul 25, 2004 | 02:59 PM
bogus's Avatar
bogus
we really need to determine why the car is getting the light... then more can be assessed.
Do you have the helms manual? It will help you pull the codes...
Old Jul 26, 2004 | 12:40 AM
wb2dyb's Avatar
wb2dyb
Default Asr
I was getting that, what it turned out to be was low brake fluid. When you fill it, it looks full...but wait several minutes, it needs to be FULL. I lost some brake action at the same time, more than usual pedal travel if needing to brake hard.
But if yours does it just casually driving along, disregard what I just said it could be.
And if that's the case, I can't help, I've yet to really have to dig into ASR...
Old Jul 30, 2004 | 02:01 AM
jabez's Avatar
jabez
I get a code 62 for my ASR problem.
Whats that?
Old Jul 30, 2004 | 09:15 AM
c4cruiser's Avatar
c4cruiser
Code 62 is "Tach Pulses Fault". Quotes are from the 92 manual:
"The tach pulses circuit provides the Electronic Brake Control Module with an indication of engine RPM to help determine ASR control methods and rates when a ASR event takes place.
The "SERVICE ASR" indicator light will be ON and Code 62 set if there is a short to ground, short to B+ or an open in circuit 121."
The manual goes on to say that "a short to ground may cause driveability problems. If the ground fault is on the ignition side of the tach filter the engine may not start or run very badly".
How does your car run?? Will it start??
Does the tach work properly across different engine speeds?? "If it does, the problem may be an open circuit between the common connection point of the instrument panel tach wiring and the CKT 121 wiring at bulkhead connector C100 terminal G."
It looks like you will need a wiring diagram to trace the circuits and their locations to trace either an open circuit or a bad ground. While the manual talks about the tach wire circuit it does not state that a tech filter is a potential cause.
Old Jul 30, 2004 | 10:57 PM
jabez's Avatar
jabez
My car has a hard time starting when engine is hot. Other than that the car runs smoothly. Everything else seem to be A-OK
Old Jul 31, 2004 | 01:07 AM
bogus's Avatar
bogus
it sounds like a tach filter problem...
To ASR question
