Chassis lube
Old Jul 25, 2004 | 07:37 PM
efweber's Avatar
efweber
Default Chassis lube
What is everyone using for lubricant on their chassis? Is there a brand I can get at an auto parts store that is compatible with what GM recommends? Any hints on procedures, things to avoid, etc? Also, is it safe to assume that a lubricant I use on my Corvette will be safe on my pickup truck, tractor, etc? I only have one grease gun, and changing grease tubes is a real mess. Thanks for the help.
Old Jul 25, 2004 | 07:48 PM
CFI-EFI's Avatar
CFI-EFI
There are only 6 Zerk's on the whole car. The ball joints and tie rod ends are made by the same OE vendors that make everything else for GM. There is nothing "special" about the chassis components on your Corvette. I just replaced mine with 160,000 miles on them. Use a good quality chassis lube on both your car and truck, and you ought to be able to sleep at night.
RACE ON!!!
Old Jul 25, 2004 | 07:49 PM
Lone Ranger's Avatar
Lone Ranger
Four lube points on the front end, where are the other two on a C4?
Old Jul 25, 2004 | 07:57 PM
wildman378's Avatar
wildman378
Lone ranger I'm with you! I can only find 4 zerks on my 95.....thats the upper and lower blal joints. So were are missing 2 somewhere...and everyone agrees there is only 6? just used to the toyota 4x4 I had having like 12 HAHA.
Old Jul 25, 2004 | 07:59 PM
hngacurv's Avatar
hngacurv
How often should you have to lube?
Old Jul 25, 2004 | 08:28 PM
CFI-EFI's Avatar
CFI-EFI
My '84 has one in each of the ball joints (2 upper and 2 lower), and one in each tie rod end (2 more).
RACE ON!!!
Old Jul 25, 2004 | 11:07 PM
wildman378's Avatar
wildman378
"and one in each tie rod end (2 more)."
O ok well on my 95 I jsut have hte upper and low ball joint zerks none on the tie rods nowonder I could only find 4 haha.
Old Jul 26, 2004 | 01:13 AM
Southern Comfort's Avatar
Southern Comfort
That is the Rear Tie rods....
Old Jul 26, 2004 | 01:15 AM
wildman378's Avatar
wildman378
No, I'm talking about the front ones I don't see any zerks on them they're sealed.
Old Jul 26, 2004 | 01:17 AM
Southern Comfort
The rear tie rods have the zerks
Old Jul 26, 2004 | 01:19 AM
wildman378's Avatar
wildman378
ur jokeing right? I looked and looked in the rear for any zerks while I was doing the front ones...u sure they're not sealed in later ones?
guess I'll have to see if i can slide under there and grease um tomorrow
Old Jul 26, 2004 | 01:21 AM
Southern Comfort
They are on the top. You will have to get up close and personal to reach them with the wheels on.
Old Jul 26, 2004 | 01:23 AM
Southern Comfort
But your 95 may be different....good luck
Old Jul 26, 2004 | 01:24 AM
wildman378's Avatar
wildman378
Alright Thanks!
Maybe since they are on top is why I didn't spot them..
so theres 4 up front and those 2 at the back and thats all the places I need to be greasing when I do an oil change?
thanks again bc I thought I had found them all
Old Jul 26, 2004 | 01:51 AM
Red Dwarf's Avatar
Red Dwarf
95 only has 4. Caution, don't give them more than a couple of shots or you may rupture the rubber boots!
Old Jul 26, 2004 | 02:17 AM
wildman378's Avatar
wildman378
"95 only has 4. Caution, don't give them more than a couple of shots or you may rupture the rubber boots!"
Ok thanks I keep hearing they have more than 4 but yeah on my 95 I only found 4 and thats on the front upper and lower ball joints.
thanks
Old Jul 26, 2004 | 04:52 AM
JasonL's Avatar
JasonL
Later C4s only have four total zerks. I think we discussed this a week ago...
To Chassis lube
