8.5" or 9.5" Wheels?
Old Jul 26, 2004 | 12:07 AM
rickso84's Avatar
rickso84
Default 8.5" or 9.5" Wheels?
I'm rebuilding an '84 and just discovered it has three 9.5" rims and one 8.5" rim. Stock was 8.5" front and 9.5" rear but this car has the Z51 suspension so I don't know if that changed the rim sizes.
My question is, which rim should I replace, an 8.5" for a 9.5" for stock setup or a 9.5" for the 8.5" for four 9.5" rims. The latter case would make tire rotations a lot easier. The tire size is stated as being the same for the 8.5" and 9.5" rims. Does that make sense?
Thanks,
Rick
Old Jul 26, 2004 | 12:09 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I believe the Z51 gave you 9.5 all the way around.
Old Jul 26, 2004 | 12:10 AM
Gary04Z06's Avatar
Gary04Z06
Old Jul 26, 2004 | 05:41 AM
silver84's Avatar
silver84
1984 stock was 8.5,,, Z51 was 8.5/9.5
I recommend all 9.5s, unless you insist on being
factory correct.
84 silver
Old Jul 26, 2004 | 11:38 AM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Originally Posted by silver84
1984 stock was 8.5, Z51 was 8.5/9.5
Both the 8.5 and 9.5 size wheels use the same 255/50vr16 tires.
Old Jul 26, 2004 | 12:01 PM
CFI-EFI's Avatar
CFI-EFI
Just for conformation. Base 1984's came with 4, 16 x 8.5" wheels. The Z51 option included 16 x 9.5" rear wheels, with the 16 x 8.5" fronts. The tires remained P255/50/R16's.
RACE ON!!!
Old Jul 27, 2004 | 10:17 PM
rickso84's Avatar
rickso84
THanks for the replies. I was leaning towards four 9.5" so that's what I'll do.
To 8.5" or 9.5" Wheels?
