Rear window defogger
Old Jul 26, 2004 | 02:04 AM
Insane1's Avatar
Insane1
Default Rear window defogger
The wire came off on side of my rear window defogger. Does anyone know if I can solder that wire back on using my soldering station? Will it damage the window? Should I take it to a glass shop to have it fixed?
Old Jul 26, 2004 | 04:53 AM
JasonL's Avatar
JasonL
Rather than solder, I used conductive epoxy from an electronics store. Been a few years, still holds great.
Old Jul 26, 2004 | 04:54 AM
hngacurv's Avatar
hngacurv
It is hard to solder in that location. The soldering tape is easier.
Old Jul 26, 2004 | 07:31 AM
Fabinatl's Avatar
Fabinatl
Yes, you can soder the wire or another back on. You need to have it good and hot and it's a little tricky doing it upside down. Put something under neath to catch the drips. Good luck!
Old Jul 26, 2004 | 08:02 AM
JackDidley's Avatar
JackDidley
The Carquest has an epoxy repair kit just for it. I also had good luck with a soldering iron. Not too difficult.
To Rear window defogger
