Runing 9-10psi
Old Jul 26, 2004 | 11:52 AM
LT1Vetteguy78's Avatar
LT1Vetteguy78
Default Runing 9-10psi
I'm thinking about maybe pushing 9-10psi through the procharger...Do i just need to upgrade to a bigger pulley? What is needed for this change....I seem to be getting a steady 7-8 when i gun it...the car runs great....what do i need to do to see 9-10psi
Old Jul 26, 2004 | 12:23 PM
Hammer's Avatar
Hammer
Probably a forged bottem end.
Old Jul 26, 2004 | 12:26 PM
vvv90's Avatar
vvv90
Don't do it!!! 9-10 psi is generally too much for the 10.4:1 compression ratio.
You won't see enough HP gains on a stock LT1 to make it worth your while. Maybe another 30-40HP, but you're playing with fire.
Old Jul 26, 2004 | 02:12 PM
LT1Vetteguy78
VVV90,
Understood, but just what would you need to make more boost? Not what do i need to handle more boost...what do i need to make more boost?
Old Jul 26, 2004 | 02:25 PM
vvv90's Avatar
vvv90
Smaller pulley. Most boost you can make out of a P1-SC is about 12-14 psi.
Old Jul 26, 2004 | 02:40 PM
LT1Vetteguy78
You sure about 12-14? The site says the Pcs1 models max boost is 30psi..Anyways Where would one aquire this pulley, do you have a part #....I ask because i might be coming into some money and i might built the engine to handle more boost....i just wanna know what to get to make more boost
Old Jul 26, 2004 | 03:10 PM
Brand-X's Avatar
Brand-X
Call procharger. They can sell you whatever size pulley you're looking for. Just know you're facing an uphill run with belt slip, intercooler maximum cfm, and dynamic CR.
Old Jul 26, 2004 | 03:13 PM
Brand-X's Avatar
Brand-X
PS-I believe the advertised 30 psi max boost is for a closed system at blower redline. As a running engine is not a closed system (i.e., air moves through it), I think you may realize something less...beside, the added heat at blower redline makes the boost nearly worthless. That would be especially true for a 10.4:1 cr pump gas engine.
Old Jul 26, 2004 | 03:47 PM
lead foot 85 vet's Avatar
lead foot 85 vet
I'm redlining my p600b and seeing 9, 10 psi...called procharger about the 24 psi claim and they said that was for a 4 cylinder engine.
I think the pulleys are like $60.00 from ati.
Old Jul 26, 2004 | 03:49 PM
vvv90's Avatar
vvv90
That's exactly right. Boost is only made when there's a restriction. i.e. engine can't move as much air as blower. Keep in mind, if you bore and stroke your motor, put some good flowing heads/cam/exhaust on there the P1-SC might not even see 12psi, it might be less, but you'll be making more power. Everything needs to be taken into consideration.
Everything you want to do is based around the following:
How much RWHP do you want?
Once you answer that question you can start building. If your answer is "I have no idea" then don't even bother because you'll just end up mismatching parts.
If you're looking for anything more than 500CHP, You're going to have to keep an eye on that D36 rear end.
Old Jul 27, 2004 | 03:16 PM
Hammer's Avatar
Hammer
it looks like you caught the performance virus
Old Jul 27, 2004 | 04:16 PM
LT1Vetteguy78
Who me <looks around> Nahhhhhhhhhhhhhhhhhhhhh.....Well ok, yes,,,,,yes i have.....
Hello, My name is Scott and i am performancemodaholic
Old Jul 27, 2004 | 05:14 PM
Hammer's Avatar
Hammer
I have it bad too.
I just finished my 383 that's putting 500 fwhp and is ready to take a 200 shot and I'm torn between getting a C5 and modding it or starting a turbo project for the C4 .
Maybe I'll buy my high school car, 1986 Burgandy 442, and put a 502 ramjet in it....
To Runing 9-10psi
