If you are @ idle and diconnect the vacuum, you should see a rise in pressure. If you give it throttle, you lose vacuum also, but dont forget, you are pulsing the injectors faster at the same time, ie: delivering fuel. If you are maintaining 44 psi. with throttle input, your regulator is functioning. I would be looking for dribbling injectors, bad or out of tollerance IAC motor, vacuum leaks, plug wires, magnetic pick-up in the dist., leaking EGR, etc...A rough idle can be hard to find...
thanks,,,much help given..exactly what i wanted to know guys......
im gonna go out and do it again and pull the vacuum off and see what goes down.ill keep informed
