Cooling Fan Problems Please Help
Old Jul 26, 2004 | 09:28 PM
Bill Harris's Avatar
Bill Harris
Default Cooling Fan Problems Please Help
I have a 89 Vette with 39,000 miles , Im having a problem with the cooling
fan running when I start the car (cold start) and then the car will idle rough with the check engine light flashing, when it gets up to tempature the fan will shut off engine light goes off and the engine runs fine.
Old Jul 26, 2004 | 10:51 PM
jfb's Avatar
jfb
The cooling fan is controlled by the ECM which turns on the fan when the engine coolant sensor under the MAF on the front of the block tells it that the temp is 228F. The a/f is also adjusted according in part to the engine temp. I suspect that you have a defective temperature sensor. You can check this out with a scan tool and see what this sensor is relaying to the ECM. With the engine cold, the sensor should not say its 228F. Both the idling quality and the fan being on could be caused by a defective coolant sensor or its wiring harness plug which I have seen go bad.
Old Jul 27, 2004 | 08:57 AM
Stingraynut's Avatar
Stingraynut
jfb - I knew I had you down as an electrical Guru
(insert smilling face here... jfb recently replied to my post about a non electrical problem and nearly lost his guru status)
S'nut
Old Jul 27, 2004 | 10:20 AM
CFI-EFI's Avatar
CFI-EFI
With jfb. However *I* would think step one, would be to see what code the "check engine light" set.
RACE ON!!!
Old Jul 27, 2004 | 05:27 PM
Bill Harris
Thanks jfb. I don't have a scan tool, but will check out the sensor, I guess the ecm could be going bad also.
Thanks again
Old Jul 27, 2004 | 08:15 PM
CFI-EFI's Avatar
CFI-EFI
Just short terminals "A" & "B" on your ALDL, to check the code(s) set.
RACE ON!!!
To Cooling Fan Problems Please Help
