power mirrors joy stick
Old Jul 27, 2004 | 09:21 PM
shawanokid's Avatar
shawanokid
Default power mirrors joy stick
i have a 86 vette. the mirrors move in and out,and the passenger moves up and down but the drivers side won't go up and down. i wanted to test the joy stick but i don't know how to get it out, any suggestions?
Old Jul 27, 2004 | 09:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Have you pulled the center console yet?
Old Jul 27, 2004 | 09:50 PM
shawanokid's Avatar
shawanokid
no, first do you think thats the problem and if it is how do i take the console out?
Old Jul 27, 2004 | 10:09 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
If the passenger side works, but the drivers does not, it's not the joystick. If the drivers side goes side to side, but not up and down, it's not the rocker switch either. I can't tell you what it is, just what it's not.
Old Jul 27, 2004 | 10:14 PM
65Z01's Avatar
65Z01
At this point it's only a guess whether the problem is in the mirror motor or the mirror selector switch.
To remove the center console I do as follows:
-remove the screws from the dash bezel, remove the screws from the center dash bezel and lift it enough the remove the screws holding the front of the center console plate. Then remove the visible screws from the senter console plate as well as the three inside the console box.
Then you can lift the console plate; if you need to remove it you will need to pop the shifter button, remove the C-clip and the shifter ****.
Before doing this check it out to see if that will give access to the mirror selector switch.
To remove the mirror glass to access the motor, rotate the mirror fully inward, put your fingers behind it and carefully lift it off the trunion.
Old Jul 27, 2004 | 10:23 PM
shawanokid's Avatar
shawanokid
is there one motor for each mirror? also do i need special tools to take mirror apart?
Old Jul 28, 2004 | 12:44 AM
65Z01's Avatar
65Z01
There is a motor at each mirror.
You only need to reach in with your fingers to remove the mirror from the trunion which holds it to the motor.
To power mirrors joy stick
