cat's ??
Old Jul 28, 2004 | 02:10 AM
ROCKME's Avatar
ROCKME
Default cat's ??
if I gut the cat's on my 94 Lt1 will it throw codes??
will I get a cheak engine light ??
Old Jul 28, 2004 | 02:11 AM
comp's Avatar
comp
not that iv'e seen
Old Jul 28, 2004 | 02:20 AM
black_89_vette's Avatar
black_89_vette
When I gutted mine, no codes were set, I only noticed a performance increase and a better sounding exhaust.
Old Jul 28, 2004 | 02:24 AM
wildman378's Avatar
wildman378
Don't gut or take off your cats if you have a 94 or newer oz senors were added in 94 past the cats to monitor them and if they're removed it may cause problems.
Old Jul 28, 2004 | 02:38 AM
ROCKME's Avatar
ROCKME
Default 02s
I can't see any 02s past the cats?? there's two in front of each but I
don't see any behind them???
Old Jul 28, 2004 | 07:32 AM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
You are right, the sensors are forward of the cats (at least in my 95 they are). You should not get a code, but mine aren't gutted so I don't know for sure.
To connect this topic with your other thread, I would just replace the cats; they're there for a reason and if your dropping the exhaust to gut them why not just replace them. Might consider new O2 sensors at the same time depending on their condition.
Old Jul 28, 2004 | 10:15 AM
wildman378's Avatar
wildman378
Well I read on the net jsut the other day and it said not do to it if you have a 94 or later.......I don't remember how it's setup on my 95 off hand but I did read that.
maybe ur ok to do it then if so go for it I saw a gain when I did it to my truck.
Old Jul 28, 2004 | 10:20 AM
wildman378's Avatar
wildman378
I found the site I read it on look.
"1. Gutted catalytic converters. Don't do this on 94 and later Corvettes. 94 and later Corvettes have a O2 sensor AFTER the cat which monitors the effectiveness of the catalytic converter. Gut the converters and you'll get a check engine light. This is one of the reasons I tell people to buy a 92 or 93 model to modify."
here is the site
http://home.alltel.net/wayne/faq.html#Removing Catalytic Converters
Old Jul 28, 2004 | 10:52 AM
AEmedic's Avatar
AEmedic
I have a 94 and the passenger side cat has an O2 sensor directly after it. I am intimately acquainted with it since I had to monkey with that cat quite a bit to change the starter yesterday.
Old Jul 28, 2004 | 12:34 PM
bogus's Avatar
bogus
hm... I read something here recently... the 94s had after O2s, but they were dummys.
a lot of queer things went on in the mid 90s in prep for the transition to OBDII. But 94 and 95 cars are STILL ODBI cars.
The exhaust folks, such as Corsa, do not distinquish a difference in their systems until 1996 (extra O2s).
I would be curious to see what would happen if any downstream O2s were removed from one of these cars.
Old Jul 28, 2004 | 01:11 PM
-=Iron Mike=-
I was under my car last night putting in a new slave cyl. and I noticed the one on the passenger side (it was upstream) I didn't look close on the driver side but I'm sure I would have noticed one downstream if it was there.
Old Jul 28, 2004 | 03:14 PM
99svrcpe's Avatar
99svrcpe
I have a 96 LT4 that I just finished 355 rebuild. with hotcam & stage III ported heads. other mods included: Exotic Muscle Long tubes, no cats, corsa Exhaust, meziere water pump, Bosch 30# injectors, 52MM throttle body, dynatech opti, Aluminum flywheel, Spec II clutch, eliminated crank sensor, eliminated secondary air injection system, eliminated post cat O2 sensors. and I had my ECM reprogrammed by Ed Wright to compensate for all my mods and I throw no codes.
Engine runs and sounds awesome, although that is with open headers because I'm still waiting for me header extentions and 4.10 rear to arrive
Old Jul 28, 2004 | 03:50 PM
HammerDown's Avatar
HammerDown
My 94 Corvette has ONE O2 sensor behind the passenger cat. IT HAS NO EFFECT ON THE COMPUTER'S ENGINE MANAGEMENT FUNCTIONALITY.
These O2 sensors were placed in 94-95 cars during the OBD 1 to OBD 2 transition. It was used by dealerships and service centers to take data that would later be used in OBD II engine management.
In other words, as far as you're concerned it doesn't even exist. You can just remove it, won't make a bit of difference.
Old Jul 28, 2004 | 04:02 PM
James94LT1's Avatar
James94LT1
the 3rd sensor is a dummy, I have ran gutted, now I run longtubes, no
cats. No 3rd sensor just zip tie the wire up and you can unhook it
completely, no codes! its to detour you thats all.
Old Jul 28, 2004 | 07:18 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I thought about the gutting thing. But wanted to stay smog legal. So I installed Random Tech Cat. Everyone can breath better, and I can pass Smog test's.
To cat's ??
