Rearview mirror
Old Jul 28, 2004 | 02:29 PM
Biggie's Avatar
Biggie
Default Rearview mirror
My rearview mirror has been loose since I got my 89 coupe. So today
I figure Ill tighten up the screw and of course the screw is stripped.
I want to drill out the screw but don't want to mess nothing up.
Any opinions would be apprciated. Thanks
Old Jul 28, 2004 | 02:52 PM
comp's Avatar
comp
new screw ?????run a tap through it first.... worth the try
Old Jul 28, 2004 | 04:26 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you can tap a small easy-out into the screw head you may be able to pull down on the easy-out while turning it to extract the screw.
If that fails, just drill it out. You can always tap it and go with a larger allen screw. The trick will be to keep it from rotating while you drill it.
Old Jul 28, 2004 | 04:46 PM
comp's Avatar
comp
if needing to drill get a left hand twist bit
To Rearview mirror
