Getting Error Codes On Scanner
Old Jul 28, 2004 | 05:23 PM
Da Mail Man's Avatar
Da Mail Man
Default Getting Error Codes On Scanner
Greetings,
I Have A 1988 Vette Coup. It Has 68,000 Orig Miles On It. The Car Was Running Fantastic Until After A Torential Rain 2 Days Ago. Now, I Am Getting Rough Idling, And It Feels Like It Is Missing While Driving.
I Added A Bottle Of Injector Cleaner Prior To This Happening So, I Don't Know If It Is "picking Up Trash" Or Water From The Tank.
I Get A "service Engine Light" Coming On Ocassionally/infrequently But, I Read On The Net That If It Does Not Remain On, It Is Most Likely A Dirty Conection.
I Bought A Cheap Code Scanner Today And Connected It To The Interior Port At The Steering Column And Followed Directions. It Gave Me A Code "12", "32", "34" .
I Think The "32" Reading Has Something To Do With The Barometric Sensor Or Egr Diagnostic Switch And The "34" Reading Being Maf Sensor Signal Voltage Low During Engine Cruise Or Map Sensor Signal Voltage Is Low During Ignition On.
What The Hell Is Going On?....this All Started After A Torential Rain! Ya Think Maybe I Have Condensation Under Distributor Cap Or Something?.......thank You Again Forum!
Old Jul 28, 2004 | 07:21 PM
bogus's Avatar
bogus
it sounds like your engine may have sucked some water up into the intake plumbing, drowning out the MAF.
I will dbl check those codes and see what I find.
Old Jul 28, 2004 | 07:28 PM
Da Mail Man
Default Error Codes On Scanner
Greetings,
Thank You For The Reply!! The Car Was Parked When All This Was Going On. It Was Running Fine Before All This Happened.......
Old Jul 28, 2004 | 07:29 PM
Da Mail Man
Ps..........i Thought About Clearing The Computer And Seeing What I Get. What Do Ya Think?
Old Jul 29, 2004 | 12:40 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by Da Mail Man
Greetings,
I have an 88 also! Code 34 is MAF low! I had problems with thisalso, turned out to be MAF relay going bad, I replaced them both and I also had a problem with the IAC motor. It was way out of adjustment and what happens is if the ECM gets a "no air flow" signal from the MAF for just one second at startup, it will throw this code too.
I cleaned and adjusted the IAC and it solved the problem. I bought a new one because that was the second time in four years it had gotten out of adjustment.
Hope this helps
Old Jul 29, 2004 | 12:55 PM
Da Mail Man
Hope this helps
GREETINGS,
THANKS FOR REPLY! I HAVE NOT A SERVICE MANUAL ON THIS CAR YET AS I JUST BOUGHT IT.
WHERE EXACTLY IS THE "IAC" - HOW DO YA GET TO IT-HOW DO YA SERVICE IT AND WITH WHAT-REPLACEMENT PART COST?.
AGAIN, WHERE IS MAF RELAY LOCATED- REPLACEMNT COST-DID THE "FIX" OF THIS MAKE A NOTICABLE DIFFERENCE?
.....THANKS AN AWEFULL LOT FOR YOUR HELP!!!!....I MEAN IT!
Old Jul 29, 2004 | 07:40 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
GREETINGS,
There are two MAF relays on the 88. They are screwed to the top of the fender wall on the left side, behind the tire and in front of the battery. They are side by side, you can"t miss them! They are both the same part number though they do different things.
The IAC is a little more difficult to find
It is located in the Throttle body at the front of the plenum,on the lower passenger side. Removing the Throttle Body is easy, theere are only four bolts, but there are a host of electrical and vacuum connections attached.
It isn't difficult,but you might want to get a manual!
The GM Shop Manuals are available from Helms, they cost a little over $100 but will save you big $ in the long run
If I can be of more assistance, e mail me
Jack
Old Jul 29, 2004 | 07:47 PM
Da Mail Man
Greetings,
Thanks For Help And Reply!.....i Have Seen The Relays Behind The Battery As You Have Mentioned.....any Idea Of Cost?......i Paln On Getting A Manual As Soon As Possible, Believe Me!
The Throttle Body, Is That The "top Piece" That Has All The "tubes" Running Down Into The Block?..i Never Had A Car That Was Injected Before And Never Had To Deal With This. Boy, Do I Feel Like A Dummy!....ya Didn't Mention How I Could Service/clean The "iac" Or Approx Cost If Bad. Any Precautions I Should Take?
I Cleared The Computer Of All Settings/codes The Other Day And So Far, It Appears To Be Idling Well. It Is To Note That I Have Not Driven It Yet So, I Will Let You Know!
Old Jul 29, 2004 | 08:02 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Greetings,
The relays should be in front of the battery, screwed to the inner wheel well. The wires on the terminal behind the battery are a subject of further discussion!
The relays cost less than $ 15 each and the IAC motor is less than $ 60
But I would definitely get the Helms manuals and an EZ link scanner $200 before I started buying and throwing new parts in to solve the problems.
You won't believe the stories you will find here of people who spent hundreds of dollars just buying new parts in hopes of solving their problems only to come up empty!
Take a little time, the L98 engine and controls are really quite simple to figure out if you understand engines and controls. The L 98 is actuallu a lot like a 4 barrel carb except electronics are constantly adjusting the settings rather than statically adjusting them on Saturdays
Old Jul 29, 2004 | 08:20 PM
Da Mail Man
THANK YOU FOR YOUR RESPONSE...HOWEVER, YA STILL DIDN'T TEL ME HOW TO "SERVIC/CLEAN" THE IAC.......THANKS AGAIN!.......PS, YA KNOW OF A CHEAP "CHIP PROGRAMMER" ON THE MARKET THAT WORKS WITH MY CAR?...
Old Jul 30, 2004 | 07:06 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Clean the IAC with spray on electronics cleaner, adjustment is kind of tricky, read the book
I would stay away from "chips" unless you have mods on the engine that might require a "chip"
Old Jul 30, 2004 | 07:35 PM
TA's Avatar
TA
Whats this "scanner" thing you speak of.................whats a matter, didn't have any paper clips handy
Old Jul 30, 2004 | 08:15 PM
Da Mail Man
THANKS FOR REPLY. OK ON THE IAC.....
Old Jul 30, 2004 | 09:32 PM
Da Mail Man
HAVE MANY PAPER CLIPS HOWEVER BOUGHT A "SCANNER" AT LOCAL PARTS HOUSE AS THEY WERE ALMOST GIVING IT AWAY, SO, I BOUGHT IT......I
To Getting Error Codes On Scanner
