Be Aghast!! -- Radiator Pics
Old Jul 28, 2004 | 05:41 PM
~SlvrFox~'s Avatar
~SlvrFox~
St. Jude Donor '05
Default Be Aghast!! -- Radiator Pics
I believe those are the words Lars Grimsrud used to describe what you might find when you open up that shroud and prepare for a thorough radiator cleaning. per the tech tip
https://www.corvetteforum.com/techti...D=53&TopicID=2
Well, my temps were looking bad. Everything was fine at 60+ mph, but once back in the city the temp would just keep on climbing. Now before I claim this as a fix, it was probably a stuck open thermostat, since the car took a long time to warm up, so I changed it too. But here is what I found when I opened up the shrowd and took to the radiator.
http://www.geocities.com/sf327th/radiator
Well, I cleaned it and straightened all the fins and the R&R wasn't what I call a 15 minute job, more like 15 hours... cause I'm kinda new at it. But now the temp guage rises steadily to just below half range and stays there even in city stop & go traffic.
Thanks to lots of folks discussing temp problems lately
Old Jul 28, 2004 | 06:12 PM
comp's Avatar
comp
Oh yes the simple,yet labor things
Old Jul 28, 2004 | 08:14 PM
TA's Avatar
TA
Yours really doesn't look that bad considering some of the pics people have posted of their radiators.
Old Jul 28, 2004 | 08:20 PM
rick lambert's Avatar
rick lambert
Yours really looked clean compared to mine But it's good to hear it cured your heating problem-just like it did mine
Old Jul 29, 2004 | 07:59 AM
~SlvrFox~'s Avatar
~SlvrFox~
St. Jude Donor '05
Actually, I believe the thermostat was at the heart of the problem, but cleaning the radiator and straightening the fins (impossible to do installed) surely improved the efficientcy of the system.
Old Jul 29, 2004 | 08:13 AM
runner140*'s Avatar
runner140*
Default Clean that radiator
Thats what mine looks like so I clean it monthly. With a 3 foot 1" pcv
pipe extension for my shop vac.
Old Jul 29, 2004 | 08:24 AM
Darkgh0st's Avatar
Darkgh0st
How hard was it to remove?
Old Jul 29, 2004 | 01:28 PM
Wheelman's Avatar
Wheelman
Simple. Just remove a few bolts that hold the shroud to the car, upper and lower radiator hoses, trans cooler lines, and the air intake/maf and you should be able to pull it right out.
Old Jul 29, 2004 | 01:36 PM
Toymans85's Avatar
Toymans85
Amazing how much debris and dirt collects there.
I know when I first cleaned mine, I think there was a total of 5 birdnest full of straw and mice nests which I could not believe as well.
Great cooling difference for me though allowing air through though.
Old Jul 29, 2004 | 02:05 PM
F1Fan's Avatar
F1Fan
dang, I'm curious to see it, but you've exceeded your bandwith allotment...
Old Jul 29, 2004 | 05:33 PM
~SlvrFox~'s Avatar
~SlvrFox~
St. Jude Donor '05
Sorry F1Fan. I've been hosting a class reunion page and things are heating up. Try back later, and it should be OK.
SF
Old Jul 29, 2004 | 06:36 PM
QuikZilver's Avatar
QuikZilver
Yours was clean!! I started running VERY hot with my 93. I ended up replacing my radiator...it was soooo gunked up (maybe 5% of the surface, you could see light through). New radiator...ran nice and cool. Sucks I replaced the radiator 2 weeks before I got rid of it. But, my replacement is treating me well.
Old Jul 30, 2004 | 09:52 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
quikzilver,
Nice to see you still hanging around the C4 section, even after moving over to the C5.
Larry
Old Jul 30, 2004 | 03:34 PM
QuikZilver's Avatar
QuikZilver
Originally Posted by code5coupe
quikzilver,
Larry
Well, the C4 section is still a lot more fun. You can only discuss BSM removal (Body Side Moldings) and floor mat options for so long. Besides, I owned my C4 for 5 years and did most of the work on it, so any tips I can pass on will hopefully save someone's knuckles from donating more blood to their vehicle.
BTW, this is a wave for all of you.
....see C5 owners do wave to C4 owners.
Neil
Old Jul 30, 2004 | 05:30 PM
xs650's Avatar
xs650
I had a bunch of crap in between my AC condensor and radiator too.
If you take a good look at how the AC condensor fits in the shrouding, you can see why. I cut foam rubber insulation strips to seal around the left, top and bottom of the condensor and a rubber flap to close the big gap on the right end of the condensor. Also sealed around the radiator. Now all the air the come in the cooling air inlet on the front of the car goes through the AC conddensor and radiator, not around them.
Seling around the condensor dosen't hlp cooling, but it keeps the crap from getting past the condensor. Sealing around the radiator does help cooling. Any air that gets past the radiator isn't helping cooling and it is also lowering the air pressure in front of the radiator atad which also reduces flow. It's not a big difference, but our cooling systems need all the help they can get.
To Be Aghast!! -- Radiator Pics
