Drag radial question
Old Jul 28, 2004 | 09:21 PM
redcorvettedave's Avatar
redcorvettedave
Default Drag radial question
Planning on doing D44 conversion soon...3.73s . My ?? is what brand DR would be best for overall use...mainly sreet driven and what would
hook the best for 3.73s?
Old Jul 28, 2004 | 09:29 PM
CFI-EFI's Avatar
CFI-EFI
I like my BFGs. I run them year 'round. Since I haven't tried anything else, I can't compare them.
Old Jul 28, 2004 | 09:30 PM
RichS's Avatar
RichS
If your planning on using them alot on the street use the Nittos' They will last much longer than the BFGs'. I had good luck with both but the BFGs' hook more consistant for me.
Old Jul 28, 2004 | 10:48 PM
da6speed's Avatar
da6speed
You will get a lot more mileage out of a set of nitto's than the bfg's. The nittos will hook IF you get them hot. My friend has a 02' Z28 that he pulls 1.60's with his nitto's.
Old Jul 28, 2004 | 11:22 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Nitto has a harder compound which makes them better for the street, but the BFG will hook better at the track.
I was all set to test the new Mickey Thompson Drag Radials, but nobody has them in stock.
Old Jul 29, 2004 | 12:06 AM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
I did the Dana 44 swap earlier this year with new 3:73's...I'm running Nitto DR's out back full time...315-35-17's...they have been fine so far but I do have to be careful in some of these heavy rains we get down here...my motor is still stock so my 60' times are no better than street tires...more consistant though... good luck
Old Jul 29, 2004 | 06:22 AM
robtx's Avatar
robtx
Old Jul 29, 2004 | 08:28 AM
HeeHaw89's Avatar
HeeHaw89
Another Nitto user here, and very pleased with them. They are on full time with great street manners along with some respectable 60 ft times.
I'll be getting another pair when these are done
Old Jul 29, 2004 | 12:42 PM
redcorvettedave
THANKS
To Drag radial question
