Rear End Question
Old Jul 28, 2004 | 11:55 PM
aklim's Avatar
aklim
Default Rear End Question
What kind of rear end do I have? According to my research I have a Dana 36. I am thinking of switching to a 3.75 ratio set of gears because the current ones I have are way too wussy. Any thoughts?
Old Jul 28, 2004 | 11:57 PM
wildman378's Avatar
wildman378
If u have a auto it's a dana 36
Old Jul 29, 2004 | 12:02 AM
aklim's Avatar
aklim
According to Richmond gear it is a Dana 36. However, their options for a gear set fits 2.73 and numerically lower carrier. So, is that the carrier I have? BTW, I do have an auto
Old Jul 29, 2004 | 12:14 AM
vader86's Avatar
vader86
You have a 2-series carrier if you have 2.73's. There is a difference between 2 and 3-series D36 carriers.
I'm sure someone makes a 3.54/3.73 for a 2-series or some way to make it work.
Old Jul 29, 2004 | 12:15 AM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
What year is the car? is it a coupe or vert? Do you know where to find your RPO codes? If so, look for G44 or G92. If you find either of those and it's a coupe then you have a 3 series carrier with 3.07 gears, if not then it's a 2 series carrier and the the gear ratio would depend on your year. If you have a vert with those RPOs it's not necessarily as cut and dried....
Old Jul 29, 2004 | 12:22 AM
aklim's Avatar
aklim
I will have to look out those RPO codes. Where would they be on the car? This is a 91 L 98 Vette Coupe with A4 tranny.
Old Jul 29, 2004 | 12:24 AM
tobijohn's Avatar
tobijohn
Bench Racer
On your year, i think they're located on the underside of the center console lid...
Old Jul 29, 2004 | 12:25 AM
wildman378's Avatar
wildman378
Does the 3 carrier make any diff in strength of it? Excuse that question if way off lol I'm not real big on diffs.
Old Jul 29, 2004 | 01:38 AM
aklim's Avatar
aklim
I doubt it does much but the problem is that if it is a 3 series carrier, you will not get away with puting a set of gears that are for a 2 series carrier.
Old Jul 29, 2004 | 07:58 AM
conv90's Avatar
conv90
I'm interested too.
My car is a 90 convertible with a 2.73. I want to upgrade to 3.07 or more...
Buying a ring and pinion is a simple swap?
Thanks and sorry for th intrusion
-Beppe-
Old Jul 29, 2004 | 09:51 AM
vader86's Avatar
vader86
Not really, the difference is in how the ring & pinion is set.
Old Jul 29, 2004 | 11:10 AM
tobijohn's Avatar
tobijohn
Bench Racer
Originally Posted by conv90
...Buying a ring and pinion is a simple swap?
No it's not. You need specialized tools and and unless you have those and experience, you're better off leaving it to a professional. Also, while there are aftermarket 3.54/3.73 gear sets available for the 2 series carrier, I don't believe there are 3.07s. The only way to get OEM 3.07s in your diff is to swap out the entire carrier in which case it would probably be cheaper and easier to just buy a used 3 series diff with the 3.07s already in there and swap out your original 2.73 diff....
Old Jul 29, 2004 | 11:16 AM
scorp508's Avatar
scorp508
Any thoughts?
Stick to street tires.
Old Jul 29, 2004 | 02:21 PM
aklim's Avatar
aklim
Even with street tires, I will have to have something better for my motor and modified trans than my G44 (3.07 ratio) in the back
Old Jul 29, 2004 | 02:22 PM
F1Fan's Avatar
F1Fan
That small of a change is not worth the money/effort.
If you have an automatic, think about something like a 3.73 instead, and 4.10s if you have a manual.
Edit: I see the "or more..." part now
Old Jul 29, 2004 | 02:26 PM
aklim's Avatar
aklim
For my part, I want a 3.73 gear rear end
Old Jul 29, 2004 | 02:28 PM
aklim's Avatar
aklim
OK, so what do I have since I have G44 and G92. Is it a 3 series carrier and if so who makes a gear set for it?
Old Jul 29, 2004 | 02:43 PM
tobijohn's Avatar
tobijohn
Bench Racer
You've got 3.07s. There are a couple different aftermarket gear manufacturers that have both 3.54 and 3.73 gears for a 3 series carrier. Richmond seems to be the name you see the most. Below are a few links to vendors who carry them. If you see the term "thick set", I think that refers to 3.x gears for 2 series carriers which is NOT what you want. At any rate, I'd get confirmation on this info as I'm just repeating what I've read here on the Forum:
http://www.ikerds.com/
http://www.ring-pinion.com/
http://www.reiderracing.com/dana36.htm
To Rear End Question
