Hesitation Question?
Old Jul 30, 2004 | 11:04 PM
CG77VETTE's Avatar
CG77VETTE
Default Hesitation Question?
My '86 just started hesitating on acceleration. Any ideas where I should start looking?
Old Jul 31, 2004 | 01:56 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check base timing, TPS setting at base idle (450rpm) and clean the TB.
Old Jul 31, 2004 | 10:31 AM
BIG JIM 54's Avatar
BIG JIM 54
Yeah,
Check what 65Z01 says. But for me with a 52mm T/B and cam, 450rpm is almost impossible. If you set the TPS at the factory recommend setting of .54V, it will still be within specs but a little high if you keep your RPM at a more normal 650 or so. Which actually makes it run a little better.
FWIW,
BIG JIM
To Hesitation Question?
