Ho do I get 300hp 91 L98
Old Jul 31, 2004 | 11:12 AM
darkred91's Avatar
darkred91
Default Ho do I get 300hp 91 L98
I would like to make 300HP with out breaking the bank need some help..Thanks
Currently: no pre cats, air pump replacement pulley, no frisbee, AFPR, Open air cleaner K&N Filter, 1:6RR,MSD coil and wires...
Old Jul 31, 2004 | 11:22 AM
vader86's Avatar
vader86
There are a couple routes, but if you only want 300 I'd look into Joe90 and Vic'89's setups.
Hooker 2149 headers, whatever catback exhaust you like (the difference is sound only).
AS&M Runners, port your plenum,and a new accel or TPiS base...and you should be there.
Old Jul 31, 2004 | 01:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you want 300hp at the crank check out those recipes. For example, Vic'89 is making around 325chp with stock heads & cam.
My L98 was building close to 300hp at the crank with stock headers, stock heads & cam and slightly modified stock intake.
If you want 300hp at the pavement you will need around 360hp at the crank and that recipe is in the L98 mods results table on my site.
Old Jul 31, 2004 | 03:22 PM
TA's Avatar
TA
My set-up is pretty similar to Vic's except I still have the stock exhaust manifold. See sig for mods and rw hp/tq numbers
Old Aug 1, 2004 | 09:36 AM
DrEvil11417's Avatar
DrEvil11417
FYI
here's what im going with:
crane roller 214/222 @.050 .488/.509 lift w/ 1.5's
ported 882's - 231 cfm @.500"
lt-1 intake
headers, true duals, lt-1 mufflers
1.6's
chip
im told to expect a little over 400hp at the crank. id see more w/ bigger headers and a free-er flowing exhaust but i prefer the stock sound and look
Old Aug 1, 2004 | 01:54 PM
Vic'89's Avatar
Vic'89
Tom - When are those Headers going on ?
300 HP at the crank is very doable with bolton's.
Vic
Old Aug 1, 2004 | 07:21 PM
TA's Avatar
TA
We just bought a house so I got sidelined a bit. Now I gotta try to sneak them by the wife
Old Aug 1, 2004 | 08:18 PM
cdnguyred88's Avatar
cdnguyred88
I'm very close to 300 at crank right now I believe....
Old Aug 2, 2004 | 12:19 AM
TIMSPEED's Avatar
TIMSPEED
Originally Posted by DrEvil11417
here's what im going with: crane roller 214/222 @.050 .488/.509 lift w/ 1.5's
Hey, that's the same cam I'm getting. I'm puting this together:
-That Cam
-Vortec Heads (The Iron 64cc heads, milled to 58cc with a thin gasket, should be 10:1 compression)
-SD Vortec TPI base / AS&M Runners / Ported Plenum
With the Exhaust system I currently have, I'm shooting for 375bhp/500tq.
Old Aug 2, 2004 | 10:10 AM
1991Z07's Avatar
1991Z07
You should be able to get there easily with bolt-ons.
Don't know if I'd personally go with Vortec heads, but there are those who have done well with them. It just takes different manifold and setup than going with a "stock-style" system. You can get some impressive flow #'s from those stock AL heads if you send them to the right place.
Follow the link in my signature to see how we got 400 hp/500 lb/ft from the 355....
To Ho do I get 300hp 91 L98
