Fellow members,
Ive done alot of porting on intakes prior to this project but Im curious. Instead of enlarging the holes to a circular 52 mm diameter, would it be just as good if not better to make one large oval shaped (SIAMESED LIKE) OPENING? Of course I would follow the outside diameter of the openings, just hog out the middle. Its an 85 so I would be leaving the egr on the bottom intact. Almost like when you look through binoculars.
Thanks,
Your oppinions will be greatly appreciated.
Fellow members,
Thanks,
As the unproud owner of two BBK 52mm TBs, let me just say that I hope you purchased an AS&M 52mm TB!
I simply port & gasket matched the front of the plenum to the new TB. I'm not sure how it will work if you cut out the center wall. For sure you will have a little more plenum volume.
I'm using an AS&M 52mm so I too am using a larger than stock TB, but if you'd siamese the two openings together as you've described, you'll have to make a special butterfly valvem otherwise you'd get too much bypass. Also between the two openings, there are more vacuum routings inside the tb for the crancase ventillation I think.. Be carefull, use a spare TB, and let us know how it went..
Ok, I just purchased a BBK, what kind of problems have you had? Im within arms reach of a TPIS throttle body. So if the BBKs are problematic, I will pick up the TPIS. Do you know if ASM and TPIS share the Throttle Bodys like they do the runners?
First of all, the OEM TB is 48 mm, but the holes in the intake are 52 mm! No porting necessary for the new TB.
Second of all, if your car is similar to my 96 (85 model?) then the center divider is full of IAC passages that will destroy your idle air balance between the left and right side of the engine.
That might not be the case for the earlier TPI's I don't have specific experience...otherwise I don't think there will be much gain-the TB is still only 52 MM. Never know though!
[QUOTE=No Go]First of all, the OEM TB is 48 mm, but the holes in the intake are 52 mm! No porting necessary for the new TB.
Thanks alot for that info! Yes its an 85. That explains why there isnt much to port.
Ill just even things out and keep the 2 holes going.
