Speed bleeders leaking?
Anybody got any ideas? Help! I'd realy like to go faster driving AX, but I hate it when I can't stop.
Thanks in advance
Subman
do you have a leak ???? Autozone pad's ,,, girlfriend says theyfeel mushie!!! she is a brake drager.... she wore out a set of met's...
from Autozone in 3-1/2 months
I Am a pain i watch how she drive's...... No we aren't M- the big M but it's the same ....Need inputI had one leeking bleeder in the set of four I got from Autozone. I just put the stock bleeder screw back in on that caliper. The other three have Speed Bleeders and I haven't had any more trouble so far.
I Am a pain i watch how she drive's...... No we aren't M- the big M but it's the same ....Need inputGet rid of the brake dragging g/f and the problem is solved.
Thanks in advance
Subman
a)remove the MC cap
b) bleed the brakes, starting with RR/LR/RF/LF...BUT
c) only crack the SB's enough to allow the fluid to flow when you depress the brake pedal. If you unscrew them too much, you will allow air to be sucked in past the threads. (patch or no patch)
d)tap the caliper with the handle of a large screw driver or some other non lethal weapon, while you're assistant is depressing (smoothly) the brake pedal. (move quite a bit of fluid through each caliper, as I believe that you have some stubborn air trapped)
e) make sure that the MC does NOT go empty and suck air. (start over, bigtime if it does!) Let us know how that goes. BTW, the PFC pads do not suck when cold, they just work better with some heat. PS..wouldn't recommend jacking the car up and running it while working on it. (Not necessary, not smart, may end up
Both of my front speed bleeders leak from around the threads when you crack them to bleed. I was told this is bad. Is this the kind of leak that you're experiencing?
subman, Check to make sure your bleeding tube is submerged in fluid during the process.
-JRC-
