4L80-E swap questions
Old Aug 3, 2004 | 10:36 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default 4L80-E swap questions
I am thinking about putting a 4L80 or 4L80-E in my 94 LT1, in place of the 4L60-E. I know it can be done, but what all is involved? I guess I would need a custom tailshaft housing for the C beam to bolt up to. What about the overall size, is there any cutting of the car involved? Would you still use the 6 speed driveshaft and automatic yoke, as with the Dana 36-44 swap? I think John Meaney has a 4L80-E in his twin turbo C4, anybody else? I have been told by several trans builders that it is only a matter of time before the 60 gives up (with over 500 RWHP). It also seems I can get a fully built 80 for the same or less than a built 60. Any help on this would be greatly appreciated.
Old Aug 3, 2004 | 10:55 PM
vader86's Avatar
vader86
Custom tailshaft for the custom C beam, custom driveshaft
probably a trans controller for the 4l80e, and maybe a flexible dipstick if the stock one for 4l80 doesnt work
as far as i know, nothing else needs to be done
Old Aug 3, 2004 | 11:40 PM
aklim's Avatar
aklim
A properly built 4L60 or 700R4 can take a lot of abuse. GM rebuilt mine and I shredded it by hooking it up to a LPE 383 making over 400HP and babying it all the way for 6 months. I went to www.rosslertrans.com, recommended by LPE, and the tranny lasted for 3.5 years with me beating on it several times a day. I drove that Firebird every day there was no snow on the ground and beat the hell out of it.
Old Aug 4, 2004 | 06:53 PM
CFI-EFI's Avatar
CFI-EFI
There is no such thing as a 4L80 (non E). You say the prices between the 4L80E and the 4L60E are similar? Does that include the core charge for the core you probably don't have? The last *I* heard, the 4L80E cores were still at a premium. On the other hand, the builder of MY 700R4 (4L60) claims it is good for 700+ hp. Most conversions, *I* have read about ran between $4000.00 and $5000.00.
RACE ON!!!
Old Aug 4, 2004 | 10:15 PM
SEEYAAA
Guest
Posts: n/a
I have a solution for you!!! I copied my post in the for sale section...
4L80E custom trans completely rebuilt,(can handle 1000hp easy)complete with custom ecm(Compushift). Unit has a digital display that shows all trans functions. Allows control of shift points firmness, shift speed, also has built in dyno meter tells you how much HP you are putting throu the tranny, trans temp ...ALL completely controllable..and much much more!. Also has Transgo shift kit which allows manual and auto shifting Dennys Custom aluminum drive shaft 3.5 inch with HD1350 anodized yokes
31 spline input ,heavy duty universals. Protorque 3000 stall speed converter. includes custom bracket to mount the custom C-arm to tranny, also has built in driveshaft safety loop.also custom dipstick tube.
I have alot of time invested is developing this setup .As you know putting a 4L80E in the corvette is not easy. I have $1200 in the control unit. $1200 in trans, $800 in the converter, $1350 in the custom drive shaft and c-arm bracket and bracket. Total $4550.00 ....the parts are brand new mint with 1000 miles.absolutly show quality and spotless, you WILL NOT be dissapointed, Direct fit bolt in and go...will not break. Asking $3500 email - corvettecrap@aol.com
Old Aug 5, 2004 | 11:57 AM
vette_tweak's Avatar
vette_tweak
Why did you decide not to go with the 4L80E setup?
Old Aug 5, 2004 | 12:03 PM
SEEYAAA
Guest
Posts: n/a
the car has evolved into basiclly a all out race car that will hardly ever see the street, im putting a glide in it now to save some LBS,,,,the 4L80E is the way to go if you plan of doing any street driving hands down!!
Old Aug 9, 2004 | 10:06 PM
POLOVETTE 94
A couple more questions...
1) on a 94 auto, is there any modification needed to the underside of the body to fit the 80 in there?
2) will I be able to use the factory speedometer (is the signal the same?)
3) what is the 1st gear ratio of the 4L80E? Isn't it like 2.48:1?
How much will that affect acceleration compared to the 3.06 of the 4L60E?
Old Aug 10, 2004 | 01:38 AM
SLOWBUSA's Avatar
SLOWBUSA
Off the subject a little. Did you hear about the new 4L65 in the C6? 650lbft rating!
To 4L80-E swap questions
