Opti to LS1 coils
Old Aug 6, 2004 | 06:52 PM
bogus's Avatar
bogus
Originally Posted by rjetrider
thanks bogus,
I hope you finish those new instructions for bob soon. His product and service is great, but his instructions made me feel like I was back in highschool science. Thanks to some older post by Mr. Mojo and you I was able to get everything else done. Any idea how your gonna get it in the car?
Thanks again for the help
I hope to have the instructions done any day now.
As for getting it in the car? It's called "lots of soldering".
I am going to bring the harness in and start lengthening wires... thats about all I can do.
Old Aug 7, 2004 | 03:10 PM
rjetrider's Avatar
rjetrider
I'm having trouble with the white wire from the LTCC. I've connected it tho the white wire from the ignition mogule but my tach doesn't work and I have a service ASR light. What is the corect wire to connect the white wire from the LTCC?
Please any help!
Old Aug 7, 2004 | 10:58 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Please any help!
Same happened to me, cut the tach filter off and the tach will work, the ASR may or may not work, sometimes the service ASR will come on and that disables the ASR, but since I shut mine off at the track it doesn't bother me.
Old Aug 7, 2004 | 11:35 PM
rjetrider's Avatar
rjetrider
Thanks, I'm gonna try that. I'll let you guys know how it goes. I also emailed bob I hope he has some good help.
Old Aug 8, 2004 | 05:03 PM
rjetrider's Avatar
rjetrider
Just finished the work on the car and everything is working and running awesome. The Service ASR light comes on but as long as the system still works I'm happy. Just like Mr Mojo said at the the track it's turned off.
I just wanted to say thanks to Mr Mojo for the help he; you beat Bob's email by a couple of seconds with the same answer.
Through all of this Bob's service has also been great; he responded to my email on a Saturday night. Few people care that much about their product or customers.
Thanks again,
Old Aug 8, 2004 | 05:08 PM
Mr Mojo's Avatar
Mr Mojo
Bob is good people.
Old Aug 23, 2004 | 02:05 PM
99svrcpe's Avatar
99svrcpe
Originally Posted by bogus
12562864 = brackets
http://www.taylorvertex.com
LT1 180* Ends - 46066
LT1 Angled Ends - 46052
Hey Bogus,
What terminals are you using for the Taylor wires on the spark plug end? The terminals that came with above kit won't fit on the plugs. What brand plugs are you using?
Old Aug 23, 2004 | 04:16 PM
bogus's Avatar
bogus
Originally Posted by 99svrcpe
Hey Bogus,
I am using the LT1 ends that are in your post. Those are the ends that will fit with the Opti, but also fit the LS1 coil.
Old Aug 23, 2004 | 04:30 PM
99svrcpe's Avatar
99svrcpe
Right....they fit the LS1 coils just fine but they don't fit my Delco spark plugs because the barrel is not removeable. So I'll have to either get different terminals or get spark plugs with a removable barrel. Any suggestions on a plug?
Old Aug 23, 2004 | 05:08 PM
bogus's Avatar
bogus
huh? that's queer. the plug ends should fit a-ok. They are the ends that come premade.
Old Aug 23, 2004 | 05:12 PM
bogus's Avatar
bogus
I will grab my digital camera and take come pics...
which wire set did you buy?
Old Aug 23, 2004 | 05:23 PM
99svrcpe's Avatar
99svrcpe
I bought:
Taylor 35271 8mm spiro-wound 30ft bulk wire
Taylor 46066 LT1 180 & 90 degree boot and terminal kit
Old Aug 23, 2004 | 05:25 PM
  #33
bogus's Avatar
bogus
oh. did you get plug ends? Thats different.
Old Aug 23, 2004 | 05:37 PM
  #34
99svrcpe's Avatar
99svrcpe
no...thats the problem all the terminals that came with 46066 kit are ends for the coils. Does the 46052 kit come with plug ends?
Old Aug 23, 2004 | 05:53 PM
  #35
bogus's Avatar
bogus
the kit I got had 8 wires, with the plug ends pre attached.
You need plug ends....
Old Aug 25, 2004 | 06:20 PM
  #36
dhiltgen's Avatar
dhiltgen
1st Gear
I just finished the LTCC conversion last week on my '95. I made home-made
brackets out of sheetmetal on the valve covers, and painted them black.
http://www.hiltgen.com/daniel/automo...ette/ignition/
I was a little nervious that the valve covers would leak around the bolts, but
I put some thin washers underneath the brackets to fill in the gap, and they
seem to be working fine. I've got one track event on them so far, and they're
working great.
