Engine Mount question
Old Aug 4, 2004 | 01:16 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Default Engine Mount question
Anyone have reason to replace their engine mounts? I'm considering replacing mine with Energy mounts and am curious if others have had any problems with the stock or aftermarket mounts.
Thanks! -JRC-
Old Aug 4, 2004 | 01:40 PM
bogus's Avatar
bogus
I will be replacing my mounts with new GM pieces as part of my engine rebuild.
If you are looking to hear and feel every engine noise, by all means, get the poly motor mounts! I don't think that for street use they are needed.
Now, if you are racing, and wish to better control engine wind-up, then yes, get them.
Old Aug 4, 2004 | 01:44 PM
scorp508's Avatar
scorp508
I replaced mine since they were 16 years old just to get some fresh rubber in there. AFAIK there are no aftermarket mounts for C4s available.
Old Aug 4, 2004 | 09:01 PM
NightFlight's Avatar
NightFlight
Replaced mine last month (found one broken) with stock GM mounts -- Figured the orginals lasted 17 years, why switch.
Old Aug 5, 2004 | 07:29 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I swapped mine side for side while the engine was out. Figured I'd even out the wear.... They looked fine at 93,000.
To Engine Mount question
