Detonation under boost fixed....
Old Aug 5, 2004 | 08:48 PM
qwiketz's Avatar
qwiketz
Default Detonation under boost fixed....
Hey guys. I was having a problem with detonation above 3500 rpm under wot. As soon as a hint of detonation set in, I'd back off it.
I figured that it was either fuel or timing related. The btm had no effect on it(adjusting for more retard) so I checked the fuel system. I checked the t rex and it wasn't getting any juice. Sure enough, one of my wires had frayed completely(I couldn't believe it!).
I rewired it up and now I'm back in business.
I really wish that they would have done it right the first time and went with a 255 walboro in tank pump with a walboro booster pump. That would be good enough for pretty much any street blown motor up to about 500 at the wheels...
Old Aug 6, 2004 | 10:41 AM
vvv90's Avatar
vvv90
Glad to hear you fixed the issue. This is exactly the reason I ditched the dual (aux) pump setup and went with a single Walbro 255lph. Someone preached to me about the importance of this. I'll pass on your experience to everyone.
Old Aug 22, 2004 | 09:46 PM
sahein's Avatar
sahein
2nd Gear
Installed a new ATI Procharger. Have about 30 minutes on it before the T rex quit running and failed the in-tank pump. When I hit the T Rex it started running again. I don't want to chance blowing my engine on a lousy pump. Since the in-tank pump is destroyed, what is the best course of action? Please help!
Old Aug 23, 2004 | 10:16 AM
vvv90's Avatar
vvv90
Simple:
www.racetronix.com
Get the GSS340 255lph in tank pump w/ harnass
30 minute install for intermediate level experience and minimal tools.
Old Aug 24, 2004 | 01:09 PM
sahein's Avatar
sahein
2nd Gear
Is the Walbro GSS340M sufficient without a boost pump for use with an ATI Procharger? Is anybody using this setup?
Old Aug 24, 2004 | 02:31 PM
vvv90's Avatar
vvv90
Yes, the standalone 340 pump is good for 500HP, and with the Boost-a-pump it's good for about 750HP. W/ Stock fuel lines.
To Detonation under boost fixed....
