Sticking Accelerator
Old Aug 6, 2004 | 12:01 AM
ynk1121's Avatar
ynk1121
Default Sticking Accelerator
I Figured Out The Problem And Thought I Just Post It In Case Someone Is Having The Same Problem.
When I First Depressed The Accelerator To Put The Car In Motion It Stuck A Little. If I Pressed The Pedal Hard Enough, It Then Worked Fine, But Makes It Jump Forward. I Cleaned The Throttle Body All Around The Butterflys With Carb Cleaner (Sprayed A Rag And Wiped It). There Was A Little Bit Of Build Up Around It. Now It Works Perfectly .
Hope This Helps Someone Out Because Its A Very Annoying Little Problem.
Old Aug 6, 2004 | 02:22 AM
bogus's Avatar
bogus
cool!
Old Aug 6, 2004 | 06:07 AM
SOVAIN1's Avatar
SOVAIN1
Thanks for the tip!
Old Aug 6, 2004 | 07:46 AM
STEVEN13's Avatar
STEVEN13
Thanks for the tip!
On my 92 I had a problem with the cable. I disconnected the cable at the ASR and throttle body and sprayed WD-40. Works great now.
Steven
Old Aug 6, 2004 | 11:04 AM
Unriced's Avatar
Unriced
Thing that stinks is that unless you rebuild the TB, you will be doing that about once or twice a month.. Still a great fix that's quick and easy..
To Sticking Accelerator
