Throttle Body Bypass
Old Aug 6, 2004 | 12:18 AM
ynk1121's Avatar
ynk1121
Default Throttle Body Bypass
The “Throttle Body Bypass” Was Already Done To My Car When I Bought It. Im Just Curious As To The Reason Of Water Going Through The TB. Is It To Cool It? Heat It? Nothing At All?
Old Aug 6, 2004 | 12:23 AM
Perfusion's Avatar
Perfusion
The purpose was to heat the TB of cars that live in winter climates. Since most of us don't fall into that category, or if we do we don't drive the cars during that time of year, the TB bypass acts to remove the unnecessary hot coolant from the TB. It really doesn't do anything HP-wise...just another thing we can add to our "mod" lists...
Old Aug 6, 2004 | 08:27 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
If you want to kill a few hours on a saturday, do it!
All it will do is give you something to do! IMHO
The water contact area inside the throttle body is miniscule!
I gues if you were to drive your vette in 20 below temps, this might help
Old Aug 7, 2004 | 04:38 AM
crkemppainen's Avatar
crkemppainen
Smokey Yunick once said
" It's easier to find a hundred places to loose a pound, than one place to loose a hundred pounds. "
basiclly....every little bit helps.
even doing a TB bypass has to improve effeciency a little.
Old Aug 7, 2004 | 07:35 AM
TA's Avatar
TA
And lets not forget that one of the biggest advantages of the the TB bypass is that you'll then be able to remove the TB without having to mess with a coolant line.
To Throttle Body Bypass
