LT1 Intake Flow
Old Aug 6, 2004 | 10:29 AM
VetteSane's Avatar
VetteSane
Default LT1 Intake Flow
Anyone ever put an LT1 intake on the flow bench? I am working on building a new engine for road racing and I need to find my intake restrictions.
Old Aug 6, 2004 | 10:32 AM
Nathan Plemons's Avatar
Nathan Plemons
The LT1 intake should flow all you need it to. I've never heard of anybody running out of flow with it.
Old Aug 6, 2004 | 11:26 AM
vvv90's Avatar
vvv90
Does the aftermarket miniram II flow any more than the stock miniram? I thought it did?
Also, what's the difference between the LT1 and LT4 miniram other than runner location?
Old Aug 6, 2004 | 12:58 PM
BlackBeast2's Avatar
BlackBeast2
I would leave it to just port matching the throttle body intake holes and gasket match the intake to head ports. And if you have a dremell tool, perhaps just smooth the inner surface of the manifold a little. That should support at least 550hp.
Old Aug 7, 2004 | 12:17 AM
Mr6spd's Avatar
Mr6spd
I think I heard of one being tested at approx 300 cfm @ 28" of water, but don't quote me on that one. But the flow number is not necessarily a good indicator of how well it will perform.
What displacement, rpm range, and power are you targeting for your race car?
Keep in mind the the Lt1 intake does have some deficiencies for a race engine: 1) The runners are too short to offer any tuning (e.g. a intake manifold with about a 6.5-7.0 inch runner would be tuned for 6000-7000 rpm, where the 3.5 inch LT1 intake would offer no tuning benefit. 2) The plenum volume is too small, 3) The first runners are very close to the TB, and the air must make a sharp bend to enter these runners. Therefore the air distribution will not be very even between the cylinders.
Old Aug 7, 2004 | 10:27 AM
vvv90's Avatar
vvv90
All of the reasons you listed make a good candidate for a blown application
To LT1 Intake Flow
