Hei Dist Cap
Old Aug 8, 2004 | 03:31 AM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Default Hei Dist Cap
I started to have a little miss under load at highway speeds (120 MPH) so yesterday I finally had some down time to check it out.
The problem turned out to be a broken terminal inside the dist cap. It was a high end cap so I didn't even think that would even be close to the problem. It just so happened that my wife was visiting in the US so I had her pick me up a new one.
Hope this helps someone else one day
Old Aug 8, 2004 | 10:00 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Thanks for the tip and glad you got the issue corrected.
Since I discovered two bad terminals on the HyperTech cap on my IROC-Z I usually recommend clipping a timing light onto each wire for diagnosing an engine miss.
Old Aug 8, 2004 | 02:42 PM
comp's Avatar
comp
get 2
To Hei Dist Cap
