changing coolant 1990 l98
Old Aug 9, 2004 | 03:10 PM
guywade's Avatar
guywade
Default changing coolant 1990 l98
what are the steps to do boys and girls, 1st what , then what , do i need to burp the system also,?? , should i change the thermostat at the same time, thanks Guy
Old Aug 9, 2004 | 03:26 PM
Flame Red's Avatar
Flame Red
I know this is not the recommended way, but this is how I do it on my 90.
Check all hoses (nothing worse than putting in fresh anti-freeze and having the hose go the next day). I loosen the petcock with the engine cold. Go underneath the engine and disconnect one of the coolent lines that go into the oil filter housing. Some remove the knock sensor. Remove the cap and put in a running hose to flush it out. Start the engine and set the heat on max. Let it run for a while, maybe a half hour, checking that it does not overheat or the hose come out!!!
Also disconnect and flush out the overfill bottle really well. Usually a lot of crud in there!
Then I let it cool (don't like to get burned). Put everything back together. Fill with recommended anti-freeze and H20. Check the level the next few days.
