bad knock under acceleration
Old Aug 9, 2004 | 05:05 PM
brian pinner's Avatar
brian pinner
Default bad knock under acceleration
When under heavy load from low RPMs I get what seems to be a loud rattling sound from the engine. ('90 L98) Sounds like it's coming from the top but I can't be sure. It started doing it all at once one day during a rain storm. One of my mufflers had deteriorated and I removed it until I could replace it. I don't know if that mattered. Every now and then it causes my check engine light to come on and the only code I get is "knock sensor." Most of the time it subsides when I back off the gas. What could this be?
Old Aug 9, 2004 | 05:29 PM
comp's Avatar
comp
have you checked timing ??? have you been using high octane fuel ??
more info
Old Aug 9, 2004 | 05:34 PM
Biggus Blockus's Avatar
Biggus Blockus
Do you have a 6-speed or auto trans?
Old Aug 9, 2004 | 05:37 PM
brian pinner
automatic trans, and I'm using 93 octane. i had my mechanic check it with his computer and seems like the engine computer was adjusting the timing a lot. didn't come up with any conclusions though...maybe a sensor? i did replace the EGR valve and the computer. It doesn't do it as much, but still does.
Old Aug 9, 2004 | 06:02 PM
Sunyi's Avatar
Sunyi
Sounds like you have detonation, maybe a faulty knock sensor or knock sensor wirering? Mine started to ping after the knock sensor wire melted/grounded after touching the header.
Old Aug 9, 2004 | 07:20 PM
mikey whipreck's Avatar
mikey whipreck
If your mufflers are that bad what does the rest of your exhaust look like? Some exhaust problems can cause an ugly knock. That's what was causing the knocking noise in my car... of course I didnt get any codes
Old Aug 10, 2004 | 08:56 AM
comp's Avatar
comp
O2 sensor OK ????
Old Aug 10, 2004 | 12:09 PM
brian pinner
thanks guys. I'll check all of your suggestions.
Old Aug 10, 2004 | 05:54 PM
GiDvEtTe84's Avatar
GiDvEtTe84
Check lifters and redjust rocker arms too.
To bad knock under acceleration
