Hello all
I need to replace the injectors in my 92 LT1 coupe. I have a shorted one and don't want to have problems down the road changing just the one bad one. Does anybody have any advice on which brand and type to go to. I was going to order Accel 24 lb. but I wanted to ask for some advice first.
Jim
I just installed the 21lb Accels in my '90 L98 and am very happy. I decided against the 24lb units as it may require the use of an adjustable fuel pressure regulator to drop the pressure. Otherwise, the care tends to run rich, particularily in open loop mode.
