Is timing adjustable on an lt1???
Old Aug 10, 2004 | 02:31 PM
Wheelman's Avatar
Wheelman
Default Is timing adjustable on an lt1???
I'm asking this for a friend with an LT1 Z28 If so, how is it done. I know you don't just turn the optispark
Old Aug 10, 2004 | 03:50 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Computer controlled only, I think. You might be able to change intial timing by reinstalling camshaft in a different position to get more advance or retarded timing.
Old Aug 10, 2004 | 04:01 PM
bogus's Avatar
bogus
What Siverbeast says...
There is no timing adjustment available to the optispark. And changing the cam timing would be simply dangerious... unless you want to get an adjustable timing gear set. I think Cloyes makes one.
The real downside? If you didn't like the changes, returning it to stock, or, the labour of tuning, would be a real bitch.
If you really want to mess with the timing curve, it will have to be done in the chip.
To Is timing adjustable on an lt1???
