Hypertech Power Programmer III
Old Aug 11, 2004 | 06:38 PM
vettme's Avatar
vettme
Default Hypertech Power Programmer III
Does any one have any input on these units. I have a LT4 with the power stat and a K&N already installed.It runs really good now and wondered if there worth the $ or is there another brand out there better for the LT4?
Old Aug 11, 2004 | 06:58 PM
Gary04Z06's Avatar
Gary04Z06
If you just need it to change tire size, or rear gear ratio it works. If your motor is stock, not much gain, wait until you do some mods and get custom tuning done. Look for a used one if you decide to get it, but probably not worth it. I got one for my car, got a heck of a deal from a Forum member, I showed some gain from the previous time I was at the dyno, but I changed some other things also, so hard to tell what added the extra hp.
Old Aug 11, 2004 | 07:28 PM
vettme's Avatar
vettme
Thanks for reply,Im a little new at this.my car is a stock '96 Collector Ed coup. Is the 330hp true or are they alittle higher?Others have told me they are around 350hp.And Im shur you seen Hyp tech's add of adding 50hp to the LT4.
Old Aug 11, 2004 | 08:30 PM
larryfs's Avatar
larryfs
I used it to change my fan temp. it works for that.
Then I started playing with my rev limiter. I think it totally removed the rev limiter. I attempted to lower the rev limter, but yesterday I was almost at 7000 RPM's, and I never hit the limiter. so I am very skepitcal about it.
Old Aug 11, 2004 | 09:11 PM
LT4MOY's Avatar
LT4MOY
Default Hypertech
If you're interested, I have a Hypertech available from my 96 LT4. It has an additional prom available as well for Cam/Header upgrade. It adds about 10-12hp to the wheels and does help with down low torque. If you're looking for serious power go custom tune or do what I did....procharger...absolutely insane power.
Oh by the way I'll get rid of it for $200.
Let me know if you're interested. Send me a personal email. Thanks.
Old Aug 11, 2004 | 10:32 PM
96BLKTN's Avatar
96BLKTN
Will the PROM work on other PP3's? I might be interested in the PROM..
Old Aug 12, 2004 | 07:15 AM
RichS's Avatar
RichS
I had one when my GS was still somewhat stock. It worked for fan setings and gear swaps. The engine tune made the car slower in the 1/4 everytime I tried it. There claims are full of crap!!!
To Hypertech Power Programmer III
