It's Getting Hot In Here !!
Old Aug 13, 2004 | 11:43 PM
Fuzzy's Avatar
Fuzzy
Default It's Getting Hot In Here !!
Went to rinse off my 92 LT1 today @ the local self-serve car wash. Before i got there, it seemed like the a/c was not as cold as normal, kinda cool then not.(worked great yesterday) Rinsed it off & headed back home (about 11/2 miles) & the green light over the "auto" a/c switch began to flash, then stopped. The car was also running sluggish w/ a miss. I did not wash under the hood. After reading the owner's manual about low freon causing the light to flash & how to pull the 2 fuses for 1 min. & replace, I tried that because I could find no signs of a freon leak. Didn't work. So, I went to drive the car to try & figure out why it was running bad. When I nailed it @ first, it bogged then jumped. After that it seemed to run better than it ever had! Got back home & killed it. Waited a couple min. & re-started. Seemed to still run rough. Parked it, got on my Harley & went to eat & have a beer!
Pretty sure it's two separate problems. Will some freon cure one? Did something get wet & maybe need to dry for the other? I'll leave it in ya'll's expert hands.
Old Aug 15, 2004 | 03:24 PM
Fuzzy's Avatar
Fuzzy
Well it sat overnight & cranked w/everything working fine. That did'nt last long though. A/C cut out again & the idle surge & miss returned. Still bogs on hard accel.. Drove it about 25 miles w/no change. Guess it's off to the Chevy dealer tomorrow.$$$$$$$$$$$
Old Aug 15, 2004 | 11:29 PM
mikey whipreck's Avatar
mikey whipreck
There is another thread right now about car washes being rough on vettes for some reason... did you happen to read it?
Old Aug 16, 2004 | 03:10 AM
madmike's Avatar
madmike
Sounds like the rinse did something. My L98 had a hose that drained right onto a battery junction box right behind the battery. Nice place to put the gutter drain hose. I lengthened it to pass the junction box. Im not sure how a LT1 is configured but its probably not that different
Old Aug 16, 2004 | 08:28 PM
Fuzzy's Avatar
Fuzzy
Well the Chevy dealer fixed the running problem today. Seems like it was a short in the ECM. It's going to the a/c tech in the A.M. to tackle that. By the way, I read a thread about NAPA selling ECM's for about $110.00. They quoted me 259.00 - 289.00 depending on # on unit. The Chevy dealer was 249.00. So far I'm 400.00 into it.
Old Aug 16, 2004 | 08:29 PM
Fuzzy's Avatar
Fuzzy
Thanks, I'll look for it.
To It's Getting Hot In Here !!
