Saw this on the C5 forum, but it's also relevant for us C4'ers. This article confirms everything I thought about heavier repro wheels. Looks like I'll be keeping my turbines
This is why I stayed away from the repro wheels. When I called around they would either not quote me a weight or give me weights that were considerably heavier than stock. I went with stock '04 Z06 wheels and I love them.
Unless you are trying to get every fraction of performance out of your vette for competion reasons I would not worry it about whether a wheel is a few lbs heavier.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
And even if you weren't concerned with rotating mass, I would never add any unsprung weight to my car either. Heavier wheels diminish power AND handling!
Besides, I kind of like maintaining stock appearance because it's just that much more fun when the real hotshoe ricers think they're just messing with another old fart in a stock Vette!
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
What he fails to mention, is that he switched to Z06 wheels, which are 1" wider, and have less positive offset than Y2ks. Both of these things mean the wheel will have more material.
The only difference between OEM and repro castings, is the mounting surface. repros are typically solid there, while OEM removes excess material between lug holes. As far as rotational mass goes, all this weight is next to the hub, so it doesn't have a big effect on rotational inertia.
Even if there were two wheels of the same material and exact same casting, and one weighed more, it means the heavier one is a higher quality casting, and will be stronger.
besides i have 478 rwhp to help offset the weight of my 19s
FWIW - This past June I held a wheel off a current Formula 1 car, you could literally hold it with your extended index finger at arms length - it was that light. In fact, I spun it of my finger. No tire, of course.
