What is this part? help.
Old Aug 15, 2004 | 06:05 PM
87 rag's Avatar
87 rag
Default What is this part? help.
On the passenger side of my 87 convertible there is a tube running off the exhaust manifold tube closest to the distributor. It runs up over the valve cover and attaches to the intake manifold. Just before the meets the intake manifold there is a sensor.
What is this? What does it do? What is the wire supposed to be attached to?
Old Aug 15, 2004 | 06:39 PM
chriswtx's Avatar
chriswtx
Thats the EGR tube...Its for the exhaust reculation valve.
Old Aug 15, 2004 | 06:46 PM
87 rag's Avatar
87 rag
Okay, but what is the sensor with the wire called and what is the wire supposed to be attached to?
Old Aug 15, 2004 | 06:56 PM
scorp508's Avatar
scorp508
EGR Temperature Switch. There is a connector that comes from down behind the distributor area that it connects to.
Old Aug 15, 2004 | 07:06 PM
87 rag's Avatar
87 rag
Thank you
I suppose it would effect the way the car runs if it's not hooked up?
To What is this part? help.
