interior lights time delay relay
Old Aug 15, 2004 | 06:13 PM
0 to 60's Avatar
0 to 60
Default interior lights time delay relay
Does anyone remember seeing a procedure to bypass the time delay relay. Mine is shot, and I'd like to get the interior lights back on.
Old Aug 15, 2004 | 06:46 PM
jfb's Avatar
jfb
Save your lunch money and buy a new delay module. The door switches trigger the delay module and you cannot directly bypass the delay module.
Old Aug 15, 2004 | 06:56 PM
0 to 60's Avatar
0 to 60
Where do you buy a new relay? Either way is OK with me. But I cannot find one.
Old Aug 16, 2004 | 12:26 AM
jfb's Avatar
jfb
Check with your local Chevy dealer.
Old Aug 21, 2004 | 04:01 PM
0 to 60's Avatar
0 to 60
Default solved it!!
It took awhile but I found the thread I was looking for. See the attached http://forums.corvetteforum.com/zerothread?id=776172
Old Aug 22, 2004 | 01:51 AM
olman's Avatar
olman
Default What I did
This worked on my 85. Pull the timer module out and connect the two white wires in the plug with a short jumper wire shoved into the plug. I'd post a picture if I knew how but I'm too old to learn. The jumper restored my interior lights and the hatch switches on the doors. No delay though.
To interior lights time delay relay
