I have a 1984 Corvette. On the passenger side, at the same level as the spark plugs, is a sensor. It appears to screw in, similar to the spark plugs. The wiring coming off this sensor does not attach to anything. It is stripped bare. Please help me identify what this part is, and where the wiring should connect. I get readings for engine coolant temperature, oil temperature, and oil pressure that all appear to be accurate. It also goes closed loop at about 140 degrees, which seems about right. Please help!
it sounds like it's your cooling fan ground sensor, between the rear two cylindrs cyl 5 and 7.
Between the #6 and #8 plugs is the fan temp switch. The ECM has no control over fan operation on an '84. The wire is .8 brown, circuit #335. At a connector it is joined by a .5 tan wire from the A/C compressor. From the other side of the connector, circuit #335 continues as a .5 dark green/white wire to terminal "B" on the fan relay. The fan relay is located on the left inner wheel well, below the front of master cylinder. When the switch reaches is designed temp, it closes and grounds the primary side of the relay, activating the fan. Switching on the A/C grounds the same circuit, as the wire routing above explains.
RACE ON!!!
O.K., great information. Now, what is the impact of not having this sensor?
From: I live at www.domesticlugnuts.com I sleep in PA
I don't think your fan will kick on until about 225 or 230 without that switch. I replaced that sensor on my 84 with one that kicks on at 155. Before I done the last major mod, my temps would stay around 175 to 180 in town.
Your fan won't come on. With the A/C off, the fan should come on at around 225 degrees, and off at around 205.
If your fan is running continually, somebody has grounded the wire that would ordinarily connect to the switch. This is a cheap alternative to replacing a faulty switch, but will dramatically shorten the life of your fan motor. I would reconnect everything correctly, and see if your fan comes on at 225 like it's supposed to.
