knock, knock, knock...
Old Aug 16, 2004 | 03:46 AM
90EXPVette's Avatar
90EXPVette
Default Pre-cats or no?
I heard this metallic knocking sound (in the front of the car) which increased with engine rpms. I needed to replace the rear bearing anyway so I ordered them and had my mechanic check the Vette out.
Turns out that the passenger side cat on the front y pipe is bad. I've seen two replacements at Ecklers one with the two pre cats and one without.
Will running a front y without the pre-cats make the Vette louder? It's loud enough as is with the Ansa mufflers. The ads state that the front y with precats is EPA approved but an identical y on another site stated off road use only...what would you guys recommend??
Joe
Old Aug 17, 2004 | 02:24 AM
90EXPVette's Avatar
90EXPVette
ttt
Old Aug 17, 2004 | 08:48 AM
JackDidley's Avatar
JackDidley
Yes. Definitely louder. I have all my cats empty and at first its really bad. Afert about 6k miles I now like it . If you dont drag race I say put cats back on it. You would not notice the power diffrence on the street. Et diffrence is about .15 with no cats. You can see it on a timeslip but I dont think you can feel it.
Old Aug 17, 2004 | 10:05 AM
TheStef's Avatar
TheStef
I had the two pre cats gutted out for the exact same reason as you, but I left the main cat intact.
It bumped the noise level a bit, but not drastically, I was told the emissions will still be ok.
Old Aug 17, 2004 | 10:33 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
A front Y without pre-cats along with a 3-stage cat is 49-state (left coast excluded) legal alternative to the stock setup.
You will get a hp gain from going to the new front Y with hi-flow cat.
Also, if you toss the frisbee from the front of your water pump pulley you will get a hp gain.
Old Aug 18, 2004 | 10:06 PM
Todd90L98's Avatar
Todd90L98
Cruising
I went with no precats and the 2 and 1/2 pipe. I also have an aftermarket catco main convertor and flowmaster exahust. The car shounds great. It was a little louder but sound good. For a pieced together system it sounds good. As for picking up any ponies ...maybe a couple. I had no problems withthe emission test in ohio but I don't think they know to look for the precats.
Old Aug 19, 2004 | 02:30 AM
90EXPVette's Avatar
90EXPVette
Thanks fellas the new Y is on the way! Ecklers should be shipping it tomorrow
65 thanks for the frisbee reminder, I've seen some of your other posts about it and had forgotten, it's coming off this weekend.
Joe
To knock, knock, knock...
