87,/c4 eliminate smog system
Old Aug 16, 2004 | 12:06 PM
EHGVETTE's Avatar
EHGVETTE
Default 87,/c4 eliminate smog system
if i eliminate the smog system on an 87 c4 do iI have to recalibrate computer. does anyone have printed directions for doing this?
Old Aug 16, 2004 | 12:43 PM
drumboytroy's Avatar
drumboytroy
I just removed mine. I have an 85. Should be pretty much the same system. I didn;t have to recalibrate anything. No check engine light, no codes, runs great. You will have to put something back in place of the air pump. Some of the Vette catalogs sells a pulley kit to replace the pump. It's from $150 to $170. That was a little steep I thought so I made my own for about $30. It cleaned up the engine compartment rather nicely.
Old Aug 16, 2004 | 02:34 PM
vader86's Avatar
vader86
Just yank off the AIR pump and put a pulley in its place, one is sold in the Ecklers and MidAmerica catalogs. Disconnect its electrical connectors and the AIR pipes from the exhaust manifolds.
No reprogramming is necessary.
Old Aug 16, 2004 | 04:07 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Cap the air line on the cat, and yank the rest off. I'd recommend leaving the EGR intact though. I gutted my smog pump because I was too cheap to buy an eliminator pulley.
To 87,/c4 eliminate smog system
