Code 43 FIXED!
Old Aug 16, 2004 | 09:35 PM
STEVEN13's Avatar
STEVEN13
Default Code 43 FIXED! (help)
Hi,
I have been chasing this problem for a while. I was getting a intermittent code 43. First a little history: Last time at the track I broke my damper and powersteering line. At first I thought it was maybe the wobble in the damper that was making noise and setting the code, or when the line broke being as it made a mess over the opti and wires giving me my problem. After fixing those problems I still had a code 43.
After checking the circuit and knock sensors (3 times) and always checking out to spec-I finally got it fixed.
It was a bad set of wires. I noticed at night they were arcing. Even with them arcing it seemed to run okay. After installing the wires-no codes. So far I have only driven the car for about 1 hour. Also compared to before it runs stronger! If it comes back I will post.
Steven
Old Aug 16, 2004 | 10:40 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Old Aug 16, 2004 | 10:50 PM
96zride's Avatar
96zride
St. Jude Donor '04 &'05
I had a 96 Z28 that did that, couldn't find it never thought it was the plug wires they were two months old, sure enough one of the B*stards was bad.
Old Aug 17, 2004 | 10:01 PM
STEVEN13's Avatar
STEVEN13
My problem is back
Qusetion: I installed new Tayor wires however I noticed that they are also arcing. They are not touching anything and are set-up neat. Some arc from the boot and some arc to other wires. Again they are neat and have wire looms attached. Can I have a bad set of wires?
Any help would be greatly appreaciated!
Thanks,
Steven
Old Aug 17, 2004 | 11:38 PM
larryfs's Avatar
larryfs
ttt for ya....
my van had a wire pop off for NO reason.
the wires have 30,000 miles on them, and 1 suddenly pops off !! no reason that I know of. No one was under the hood. just popped off a plug. I drove it 30 miles before finding it. annoying miss...
Old Aug 18, 2004 | 06:34 AM
STEVEN13's Avatar
STEVEN13
Thanks Larryfs
Old Aug 18, 2004 | 06:55 AM
SupaVette's Avatar
SupaVette
Do you have a MSD installed?? when one of my plug leads broke, i used standard leads as a temp measure. Man at night it looked like a disco under my hood. the leads where glowing blue. Once i installed my proper leads no problem
Old Aug 18, 2004 | 08:04 AM
STEVEN13's Avatar
STEVEN13
Supavette,
No MSD, stock opti. I have a stupid question: When you say plug lead do you mean the spark plug wires?
Thanks for replying,
Steven
To Code 43 FIXED!
